Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 05-04-2017, 10:59 AM   #141
DBHWT
DBHWT's Avatar
Drives: 2013 SS 1LE
If someone as added aftermarket seats, such as Braum, could you add a DIY to get rid of the air bag light .....has to do w/adding resistor in circuit wiring...thanks !!!!!!
DBHWT is offline   Reply With Quote
Old 02-07-2018, 10:16 AM   #142
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
try here
http://www.camaro5.com/forums/showthread.php?t=434170
Old 02-16-2018, 02:20 PM   #143
alv927
alv927's Avatar
Drives: 2013 camaro 2ss/rs dusk edition
E brake cable
Has anyone had an Ebrake cable break on them? just happened to me as i pulled into the garage. How hard is the repair ? and roughly the cast or part number for the replacement part. I own a 2013 SS
alv927 is offline   Reply With Quote
Old 03-08-2018, 08:10 PM   #144
Syncamaro1234
Drives: 2011 LS camaro,synergy green
JBA headers
Just curious,a shop put on short headers for me today,and noticed they didn't put the heat shields on the front.will they not work with the headers or they forgot to put them on.thanks for any response.
Syncamaro1234 is offline   Reply With Quote
Old 04-02-2018, 08:34 AM   #145
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Need to figure out how to get all these photo bucket pictures converted to something that is veiwable.
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 08-21-2018, 07:27 PM   #146
BLU DUCE
BLU DUCE's Avatar
Drives: 2011 1SS/RS IBM Camaro
Got the brembros off,brake rotor off. I have a broken wheel stud on the back axel right wheel hub. How do you get the hub off to get the stud out and put back in. Thxs.
I forgot I have all 4 manual for this car. Went doing some searching & reading. I found out just what I needed and had to do 15 minutes work to get the hub off with out a pulley. Got the stud out and decided to replace all 5 of them. For $2.79 a piece well worth it in my opinion.
BLU DUCE is offline   Reply With Quote
Old 08-30-2018, 07:45 AM   #147
jokrz187
jokrz187's Avatar
Drives: 2015 1SS
great thread, i'm glad i found this. thank you to all you have shared their innovations.
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill.
jokrz187 is offline   Reply With Quote
Old 09-12-2018, 09:03 PM   #148
15RS2NV
Ponies are for girls
15RS2NV's Avatar
Drives: 2015 RS LFX Red Hot A6
Anyone try modifying the outer lines on an LFX intake plenum? I've thought about shaving them down then painting to look aluminum, for show purposes. I like to show the engine and for me, that this is ugly.
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
15RS2NV is offline   Reply With Quote
Old 09-13-2018, 06:01 AM   #149
jman17
jman17's Avatar
Drives: 2011 SS-2/1969 SS
I thought I remembered a LS7 build DIY thread somewhere on Camaro5. Does anyone know where that one is or was?
1969 SS: SS/DA 427 CI/Auto
2011 SS-2 LS3 M6 MODS: P1X ProCharger, Squash dual fuel pumps, ID fuel injectors, Cam: Pat G designed/EPS Ground (228/234 .629”/.629” 114 LSA +4 advance), Lethal Racing ported throttle-body and intake manifold, Kooks 1 7/8” Long Tube Headers, Dynomax Bullet Cat-Back System, Skip Shift Eliminator
jman17 is offline   Reply With Quote
Old 10-19-2018, 11:24 AM   #150
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Subframe bushing removal/installation
https://www.camaro5.com/forums/showthread.php?t=540578
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 03-23-2019, 10:21 AM   #151
malone.fannin
malone.fannin's Avatar
Drives: 15 ZL1
15 ZL1 convertible.. I'm wondering if there is a way to get the additional 3 competition modes (factory on HT) that are not available on convertibles. Has anyone done it and how?
Sent from my Moto Z (2) using Tapatalk
malone.fannin is offline   Reply With Quote
Old 06-06-2020, 10:16 PM   #152
BLCKJACK
BLCKJACK's Avatar
Drives: 2015 BLCK 2SS/RS 1LE
Anyone done a DIY or have pics for installing the FAST LXRT 102mm intake manifold?
I just bought one and see some modifications need to be made to install it on the LS3. I am also trying to see if I can use my CAI cold air intake with a Nick Williams 102mm Throttle body.
2015 Black 1LE, COMP 54-454-11 Camshaft, Johnson short travel lifters, BTR .660 dual vlv springs, COMP Max-Lift BSR Shaft Rockers, CAI intake, APEX racing scoop/washer reloc kit, FAST 102 LSXR intake ported by Vengeance Racing, Nick Williams 102mm TB, GM Perf CNC ported heads, Stainless Power Long Tube headers, Fluidampr 25% underdrive balancer, Elite E2 catch can, dynotuned by DTP Racing 525 RWHP/495 TQ, Ghosted Oracle sidemarkers
BLCKJACK is offline   Reply With Quote
Old 10-27-2020, 07:42 PM   #153
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
Any DIY on removing the 6third brake light in a 14-15 SS?
A man's garage is his castle
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2014 Camaro SS Dedicated Track Car
2015 Camaro 1SS 1LE
2008 HHR SS
1996 Silverado Crew Cab Long Bed Dual Rear Wheel
SS Performance is offline   Reply With Quote
Old 10-27-2020, 08:11 PM   #154
This is about it... https://www.camaro5.com/forums/showt...ight=3rd+Brake
DIY Hurst Short Throw Shifter Install - Pix and Video TAG UR IT Camaro DIY & HOW-TO instructions & discussions 121 02-26-2015 10:08 AM
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 06:11 PM
DIY Vinyl Bowtie Black Outs srevoal Camaro DIY & HOW-TO instructions & discussions 3 12-11-2009 06:13 PM
DIY lowering springs install?? BOULI306 Camaro DIY & HOW-TO instructions & discussions 3 12-08-2009 06:38 PM
Should you DIY headers install... or should you pay to have it done Jakefeb3 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2 11-10-2009 07:27 AM
