01-18-2018, 04:06 PM | #1 |
Step by Step Video Guide: How to upgrade to a ZL1 Master Cylinder in your 5th gen
I upgraded my master cylinder over the summer and created a detailed, step by step video guide showing how to replace and / or upgrade the master cylinder on your 5th generation Camaro. CLICK HERE FOR THE VIDEO This is an upgrade to my stock 2012 V6 Master Cylinder to the larger ZL1 Master Cylinder to complement my ZL1 brake upgrade (video coming soon).
I would recommend that you bench bleed the new master cylinder to remove as much air as possible from the system. I show how to properly bench bleed the master cylinder in the following link: Click Here Get it your own master cylidner here! http://amzn.to/2FONpts 5th Gen Camaro (2012-2015) ZL1 Master GM Part Number: 22956541 |
01-18-2018, 04:37 PM | #2 |
Drives: 1969 R/S Z28 302 m20 Endura Join Date: Sep 2009
boy thats alot of brakes for a V6 car but better to have too much brakes instead of not enough
1969 RS Z/28 302
1969 Firebird LS6-6 speed TA clone 2015 Zl1 |
01-19-2018, 07:49 AM | #3 |
Probably not completely necessary but I got the parts second hand and pieced it together over time for a good price - really fill out the rims nicely and braking is
01-19-2018, 09:54 AM | #4 |
Is there a difference between the ZL1 and SS MC???
Orange Krush II
01-24-2018, 04:19 PM | #5 |
I do not believe so. For the 2012 model year they share the same part number: 22956541. I did not check the other model years.
01-24-2018, 08:04 PM | #6 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
2013 ZL1 and SS master brake cylinders are the same, V6 are different
Tags |
how to upgrade your master cylinder, replace master cylinder, upgrade master cylinder, zl1 master cylinder |
