Vararam
Old 11-30-2014, 02:32 AM   #1
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
forged 416 build
the timing chain broke and caused a fair bit of damage, that coupled with my aversion to failure, I'm hopefully going to build a motor that I can get more than 25,000miles out of.
failure and diagnosis here http://www.camaro5.com/forums/showthread.php?t=382495
Old 11-30-2014, 03:54 AM   #2
h018871
Geoff
h018871's Avatar
the plan
1st tore it down and assessed the damage
Good Parts: block, heads, clutch, rockers, rods, a couple of pistons and the crank could be reused, but it needed some work
Bad Parts: chain (duh), cam, some pistons, most of the valves, crank needed some work, oil pump, metal everywhere..........
with the above and the plan to keep road racing on weekends and having the car as a true daily driver we decided on a few necessities and a few good to haves and some things just because
forged stroked bottom end with a slight bump in compression
custom grind on a 3 bolt cam motion core from BTR designed for torque and sustained high RPM
keep the 660 BTR springs (tested good)
reuse the comp cam trunions (checked good)
LS2 "bow tie" tensioner
C5R Katech chain and factory gears
another high volume oil pump
CNC the intake and exhaust runners on the stock heads
polish the combustion chambers for heat control
head studs
oil pan baffle
external oil cooler
ATI 10% under drive balancer
auxiliary oil temp gauge
under hood fuel pressure gauge
data logger for smart phone
all I have so far is the pan baffle and the heads
the pace should pick up after this weekend
Old 11-30-2014, 06:53 AM   #3
SSSoon
SSSoon's Avatar
Drives: RY 2011 2SS A6
Sounds like a good plan! Subscribed and looking forward to seeing your build progress.
Dry sump LS7, cage, JPSS suspension, Wilwood brakes, fire suppression, ARH 3" headers/exhaust, Z/28 DSSV coilovers, Kirkey seats, TeamTech 6-point harnesses, 19" Forgeline GA3R, 325/30R19 Re11 tires, oil cooler, monster JPSS splitter/wickerbill, CAI, brake ducts.
SSSoon is offline   Reply With Quote
Old 11-30-2014, 08:20 AM   #4
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
be safe this time go with a nice Fluidampr harmonic balancer to help engine vibrations and a nice timing chain would help and also driven racing ls30 oil,,,, that's all the advice I can give, and your old cam did have a lot of wear and metal shavings around it in your pics. Good luck. I do know that a comp cam gear drive has been made also......
christianchevell is offline   Reply With Quote
Old 11-30-2014, 11:37 AM   #5
1989GTA
Drives: 1989 GTA Trans Am
Subscribing to the build.
1989GTA is offline   Reply With Quote
Old 11-30-2014, 02:47 PM   #6
62nalide
62nalide's Avatar
Drives: 2013 SS
Oh I like this!
62nalide is offline   Reply With Quote
Old 11-30-2014, 02:49 PM   #7
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
Subscribed.
Camaro Dude is offline   Reply With Quote
Old 11-30-2014, 06:54 PM   #8
Muscle Car Lover
Muscle Car Lover's Avatar
Drives: 2014 2SS M6 "CHRISTINE"
This should be GOOD! Subscribed!
"But, House Mormont remembers. The North remembers! We know no King but the King of the North whose name is Stark. I don't care if he's a bastard. Ned Stark's blood runs through his veins. He's my king–from this day until his last day."
Mods: ARH headers and hi flow cats, VMAX ported throttle body, CAI air intake, Slowhawk Performance tuning
Muscle Car Lover is offline   Reply With Quote
Old 11-30-2014, 07:56 PM   #9
Ivan @ Southwest Speed
Drives: '15 Z06, '01 NBM SS, '97 SS
You have my attention....
Gorgeous oil pan baffle setup.
Ivan @ Southwest Speed is offline   Reply With Quote
Old 12-01-2014, 12:19 AM   #10
h018871
Geoff
h018871's Avatar
for the balancer/damper I went with the builder. he had not heard anything bad about the fluidampr, but did not have any personal experience with it and said he and his buddies all run the ATI. I'm a lemming
C5R chain is in the plan, I'm not an early adopter, so i'll pass on the gear drive......
thx for the suggestions!
Old 12-01-2014, 12:22 AM   #11
h018871
Geoff
h018871's Avatar
sooooooo true, it is sweet looking. I know that I am not an early adopter, but this looks so good and I don't see how I can go wrong with it. this definitely falls into the "just because" category of purchases!
Old 12-01-2014, 06:23 AM   #12
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Saw that gear drive at SEMA....very interesting but not sure I would spend that money. C5r chain is well proven.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000,
realcanuk is offline   Reply With Quote
Old 12-01-2014, 09:13 AM   #13
Jason 98 TA
Drives: Camaro
Give us a call if you need help on the short-block or short-block parts. With over 200 crankshafts in stock, 200 sets of rods & probably 60 sets of pistons I bet we have something to get you going. We can even machine the engine for you. With the TSP short-block setup you get cnc digitizing & blueprinting to make sure your bores, decks & cam to crank correlation is correct. That's something nobody else in the LS industry can offer!!
Jason 98 TA is offline   Reply With Quote
Old 12-01-2014, 06:10 PM   #14
h018871
Geoff
h018871's Avatar
thx Jason
most things are ordered..................just waiting on the UPS man to do his thing
