06-07-2014, 10:51 PM | #57 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
Thanks!
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
06-27-2014, 11:32 AM | #58 |
I have seen this asked
I have done allot of gears in my previous life and needless to say I have had a couple come backs Either from a defect, just getting in a hurry or someone deciding to tow a trailer before putting any miles at all on the new gear set.
I just did my rear in my SS with the 3.91 1 LE gears and noticing the gear cut was different I did some research and posted the results below. And I might add that doing your own ring and pinion with the 1 LE gears can be done by a novice, it is time consuming as you always want to take the time to check and re check. If it can go wrong it will.. The 2 cut gear is the reason allot of these installs are being successful Pinion Bearing Pre-Load Rotational force with no ring gear installed 15-25 in lb spec for new bearings 9-15 in lbs on used bearings Go to far on the crush sleeve then replace sleeve and start over it cannot be backed off. Backlash on AAM OEM Gears .003 to .005 ( It is tight because these are 2 cut gears ) NOT 5 cut like most aftermarket gears which will have there run settings marked on the pinion. Pattern on 2 cut gears Will give a more diamond shape pattern which should be center on the ring between toe and heel and face and flank that is how you can determine if pinion depth and backlash are correct. Difference between a 2 cut gear and a 5 cut. 2 cut gears are the same height at the toe ( Inside Of Gear ) as it is at the heal ( Outside of Gear ) 5 cut tooth height is shorter at the toe (inside of gear ) and is taller at the heal ( outside of gear ) .... With this said you can see how a 2 cut gear would not be as problematic with pinion depth because of the lack of the additionl taper in the ring gear as it meshes. |
06-27-2014, 12:11 PM | #59 | |
Drives: 2010 2 SS Join Date: Oct 2013
Any sepcial tools needed other than dial indicator and torque wrench? |
06-27-2014, 12:13 PM | #60 |
Writer
Had mine installed by Speed Inc. I was there the whole time and am writing it up for an article. Daniel what backlash did you shoot for?
PROJECT HEAVY CHEVY
06-27-2014, 01:26 PM | #61 |
07-03-2014, 09:27 PM | #62 |
Drives: 2016 Camaro 1SS A8, 1998 K1500 5spd Join Date: Aug 2010
Sorry for the late reply. Gm specs on backlash are .003 to .010 but .005 to .007 is preferred. I usually shoot for 4-5 on high performance applications especially with aluminum housings because on a hypoid cut gearset the ring and pinion try to separate from each other under a heavy load.
*2016 1SS A8-12.100 @115 Bone Stock.
11.54 @116 with cat delete, converter and dr's Previous Rides 2010 Camaro 1SS M6-12.14 @114 Bolt Ons 2014 GMC Sierra SLT 5.3/6L80 |
08-05-2014, 07:46 PM | #63 |
Drives: 2001 camaro ss Join Date: Jul 2009
Ring and pinion install
Hey Daniel I just received a set of 3.91 gm gears and I noticed the pinion doesn't even have a pinion depth setting stamped on it . Also no markings on the ring gear but I am assuming the backlash spec in the gm manual shows .005 backlash as you said earlier. I have assembled 8-10 rearends before but never dealt with aluminum center section. The carrier bearing preload I found in the Manual shows adding around .006 to the housing opening to gain preload with an added torque spec of 10 inch pounds of pinion drag. That all sound about right ? I'm a little gun shy. Just went threw my 4.33 junk gears from Richmond on my first past attempt rounded all the gears off both ring and pinion so now I will be installing these 3.91 gm gears but other than the pinion shim I didn't record the shims originally in the housing when I removed the 3.45 gears any input or tips would be greatly appreciated
08-30-2014, 11:15 AM | #64 |
Drives: 2014 2SS/RS - SIM Join Date: Apr 2014
Subscribed
12-21-2014, 03:31 PM | #65 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
What is the torque for the rig gear bolts?
is it a stepped torque or go to spec once the gear is seated? thx in advance
12-21-2014, 04:07 PM | #66 |
Robert
Drives: 2011 Summit White SS LS3 Join Date: Feb 2011
It Depends on which axle you have but you should be able to look at yours and see pretty easily ... Hope this helps
12-21-2014, 04:14 PM | #67 |
Geoff
Perfect, Thx Robert. I have the 218
12-21-2014, 04:17 PM | #68 |
Robert
also I put the ring on the BBQ and the posi in the freezer and they fell together ... No need to step torque or press it on then I torque to per the spec I posted above (based on my axel)
Turbonetics T76 10psi with aem truboost controller, 231/239 115 LSA Comp Cam, adm fpcm, zl1 pump, Tr7ix plugs, 3.91/1LE Gears,Melling Oil pump, custom intake, catless midpipes, powerbond 25% underdrive, PFADT Aluminum subframe bushings, 1.5 inch drop, PFADT sway bars, BMR; sub frame connectors ,Trailing arms, Toe Rods, strut tower brace and rear diff bushings, Hurst short throw shifter and line lock,dyno #s TBD, , tuned by Pat G tuning
12-21-2014, 04:22 PM | #69 |
Question for guys who have done this swap and have v6 manuals . Any issues starting out in 1st gear ? Thanks
12-21-2014, 04:57 PM | #70 | |
Geoff
How did you spread the case? I heated the case to be nearly hot to the touch (with a heat gun) and the dif is cold. I'm afraid that I will break the shim trying to push it in
