08-15-2017, 05:20 PM | #43 |
Drives: 2017 Camaro 2.0T 8AT Join Date: Nov 2016
Had my Camaro in the shop for 2 1/2 months while they were waiting on parts. Torque Converter was replaced and the issue was resolved for about a month. Now same issue with shuddering is reoccurring and I dropped it off last Thursday. Let's see if I can have my car out of service for 5 months for its first year! :P
This is my first automatic I've had in years and will definitely be my last. I regret not getting a manual :-/ Sent from my iPhone using Tapatalk |
08-21-2017, 07:52 AM | #44 |
Drives: 2017 2SS Join Date: Apr 2016
I have been experiencing this issue for quite a long time. For whatever reason, I thought it was normal. I'm glad I found this thread! I will contact my dealer with TSB in hand and hope that they can resolve it quickly.
2017 HBM 2SS A8|F55|NPP|H01|IO6|RIK|WGL|56R
08-21-2017, 08:03 AM | #45 |
Train Driver
Drives: 2018 Summit White ZL1 1LE Join Date: Jun 2013
I had my fluid flushed because of this same issue. 3 times driving on lift between flushed, etc. Picked it up and is smoother than it's ever been. I hope it stays this way. About 150 miles on it so far.
2018 Camaro ZL1LE
/ / Katech TB // RotoFab Dry // Borla 60606 // ATI Super Damper / / |
08-21-2017, 08:30 PM | #46 |
Drives: 2017 2SS Join Date: Aug 2016
I just had this done as well, and like you, think it is now smoother than ever, with noticeably better shifting. That shuddering was starting to freak me out, so I am glad that this seems to have resolved it. I guess time will tell if this is a permanent fix of not.
2017 2SS A8. Maggie Heartbeat, Rotofab, Niche 20" wheels with 275/35 305/35 BFG Comp 2 A/S tires.
08-22-2017, 06:59 AM | #47 | |
Drives: . Join Date: Jul 2017
08-22-2017, 08:02 AM | #48 |
Changing fluid to fix converter shudder is a bandaid...the damage is already done. The dealership should go straight to changing it out and call it a day!
2016 NFG 1SS A8
08-22-2017, 09:59 AM | #49 | |
I'd like to be better informed about two things surrounding this issue 1. The root cause IE design, manufacturing or programming. 2. Really, how common is the failure? There are a ton of these TC's out there... |
08-24-2017, 11:04 AM | #50 |
Drives: 2016 Camaro 2SS Join Date: Oct 2016
Brought my car to the dealership today for this issue and hopefully it'll get fixed. I'll post an update asap.
08-28-2017, 07:54 PM | #51 | |
If future me is reading this post, let's hope you managed to get that Lingenfelter package and the transmission is holding up flawlessly!
08-29-2017, 12:16 PM | #52 |
Got my car back on Friday after only 2 weeks this time. They flushed the fluid (not sure if 3 times) and reflashed the TCU. Hard 1-2 shifts are gone. Haven't really had much time to try and replicate the shudder because of this pesky hurricane. Not sure why they didn't do the fluid flush when they replaced the TC. Hopefully this TC isn't ruined as well :-/
08-30-2017, 07:08 PM | #53 |
Drives: Wife's 14' IS 250 Join Date: Mar 2014
Got my TC replaced in November 2016. Sadly as of last week the shakes are back!! So I'll be going back to dealer for round 2.
-11% tint all around Ordered • 2/06/16 Built on • 3/22/16 Adopted • 4/07/16 Sold on 2/05/16: 2014 Camaro SW L99, 2SS, RS, NAV, Inferno Orange Interior: -Borla ATAK catback -Range AFM delete -15% tint all around -Red LED interior bulbs -55k white Cree LED fogs -License plate LED bulb swap -12" Sub Kit, BA amp swap -Oracle ghosted LED sidemarkers |
08-31-2017, 10:01 PM | #54 |
Took mine in at approx. 10,000 klm, (6200 miles) because of this issue...
they did a test drive and told me it was due to the tensioner on belt. Service manager mentioned a tsb about it... and this is after I let him know of all the research I did about it and mentioning the TC and tranny oil changes being done with other owners.... so they have the tensioner on order and want to replace it anyways... not sure why this would be the cause but they seem to think so. I guess I'll find out and post results when I know here. |
09-01-2017, 12:27 PM | #55 |
Drives: 2SS Garnet Red Tricoat (SOLD) Join Date: Dec 2015
I'm glad I stumbled on this......
WOW.....I'm having the same issues. Took it in a couple weeks ago and went on a test drive with service tech. I was noticing it more when engine went from v8 to v4 so I was suspecting AFM issue. This is all highway driving to and from work when I notice it the most. Got it to do the shudder several times on test drive and tech said that was normal shudder during afm swap. I wasn't really buying it but figured I'd deactivate AFM and just move on. Well now I have a copy of this TSB and will be taking car in soon and having them actually confirm this issue. Glad I stopped back in here. This forum and it's members are always a great resource.
09-01-2017, 01:14 PM | #56 | |
Drives: 2019 Dodge Challenger Scat Pack Join Date: Jun 2016
Sent from my VS500 using Tapatalk
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
