07-30-2023, 08:56 PM | #15 |
I don’t think there is much difference between the Z28 ones and the SS ones. There was a cutout in the steel in the top but there didn’t seem to be much difference in the rubber. I would just use the SS ones.
07-31-2023, 06:23 AM | #16 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
The Z28 and 1LE units are supposed to be a bit thicker and stiffer than SS ones, but I have a 1LE set up on the vert using SS rear shock mounts. That car is a creampuff compared to the turbo car with all it's mods.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
07-31-2023, 06:51 AM | #17 |
There may be some differences between the SS and z28 but they can’t make much difference. I remember thinking when i swapped mine that it was likely a waste of time and money.
07-31-2023, 07:09 AM | #18 |
Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I figured I would swap them in when I swap shocks, I have no idea if they are better or not I have just heard they were stiffer so I figured I would grab a set before they are gone. I have not looked but I would think that some aftermarket performance shock companies would offer them.
GM 3.91/TrueTrac OEM ZL1 Rims, Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,Remote Clutch reservoir
GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, Moroso Catch Can GC Aluminum DS Stainless Works Ceramic LTH/HiFlo Cats SCT X4 Dynosteve, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights AeroForce Dual gauge/Autometer pillar mount. |
07-31-2023, 09:07 AM | #19 | |
07-31-2023, 10:06 AM | #20 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
That was my exact thought as well.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
