07-19-2015, 07:35 AM | #15 | |
Yeti's Daddy
Drives: ATS-V, Prowler, M6 V10 Join Date: Jun 2015
Exactly what I was going to say. I'm going to track my car about 6-8 times a year, so I'm going to order it, but if your car is not going to see road course often, there is no need. (Just hope it's not too expensive option.) DREWZ SS: it is perfectly normal for performance cars (look at Corvette for example) to have stronger brakes for front. Indeed, I thought it was strange for Camaro to have 4 piston all around. Last edited by jaymsu; 07-19-2015 at 07:49 AM. |
07-19-2015, 09:53 AM | #16 |
Drives: '14 Z51 C7 SC'd, '14 S4, '15 SQ5 Join Date: Jul 2015
That is still with steel rotors?
That is pretty expensive considering you can buy a 4 wheel Z06 setup for the C7 for 3K, including all 4 calipers, pads, and rotors in steel from GM Parts Warehouse. The ZL1 and C7 Z06 use the same caliper so seems to be you could do the fronts along for under 2K yourself. That would make me wonder if the booster and master cylinder itself is different too. If its just the calipers, rotors, and pads that are different I'd do it myself afterwards. If its master cylinder, booster, ABS system changes then the factory makes more sense. |
07-19-2015, 01:30 PM | #17 |
Drives: 14 Camaro - 92 Corolla Join Date: Jul 2015
07-20-2015, 09:30 AM | #18 |
Yeti's Daddy
Just curious. Why do you think it's not factory option? It's shown in the build option list, which makes me believe it will come from the factory with 6 piston. If it is installed at dealership, they would waste perfectly good 4 piston caliper every time they replace it. (GM won't put the calipers that were taken out of one car in another car. Dealers may be able to sell it as 'used' or 'refurbished' at discounted price than same one in new condition, but why would they do that?)
I've been to many different car assembly plants, including LGR where Camaro will be built. Putting a different caliper, per the build order, on otherwise same type of car isn't that hard. It doesn't cost them any more labor cost - just higher material cost (comparing 4 piston vs 6 piston). If they have to swap out at the dealer, then it will cost them a lot more labor (to take out old part and put in new one), and waste of parts. So.... I'm quite positive 6 piston will come from factory, if you order the car with with 6 piston. Last edited by jaymsu; 07-20-2015 at 01:36 PM. Reason: stupid typo.... lol |
07-20-2015, 09:31 AM | #19 |
Yeti's Daddy
I don't have any experience with Gen5 ZL1's 6 piston, but I used to have C6Z06. Those 6 pistons can really stop you....FAST! I would love the 6 piston with steel rotors on the Gen6 Camaro. (Carbon rotors are great, but when you have to replace it, you wouldn't like the bill)
07-20-2015, 09:38 AM | #20 | |
Yeti's Daddy
07-20-2015, 10:44 AM | #21 |
Im the boss
If I ordered this option, I would request to keep the 4 piston Brembo's. Why let the dealer keep a part that you paid for?
Camaro SS #0785 - 1 of 280 SS's that were pewter, auto, and T-Top - SLP Headers, LM1,Y-pipe, high flow cats, SLP Lid
07-20-2015, 12:27 PM | #22 | |
Drives: 1981 silver corvette,Hyper Blue 2SS Join Date: May 2015
wouldn't expect them to include the missing piece of the roof if you order a sun roof |
07-20-2015, 01:11 PM | #23 |
Im the boss
Bc this is a dealer installed part. If you opted the dealer to install your moonroof you could keep the cutout if you wanted. If you bought a set of wheels as dealer installed, would you give them your factory wheels?
07-20-2015, 01:31 PM | #24 | |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
Both kits say they are LPO's, so they would not be factory installed kits. I'm sure some variants will have them from the factory, but the lower trims that want more performance will have the dealer installed options. |
07-20-2015, 01:34 PM | #25 | |
Yeti's Daddy
Or maybe, I'll just use what comes with the car, and replace it with 6 piston one when it's time to replace calipers. (yeah,,, track days are pretty hard on brakes, especially on front ones) Last edited by jaymsu; 07-20-2015 at 01:45 PM. |
10-27-2015, 09:04 AM | #26 |
Drives: '06 Pontiac GTO M6, '19 F150 2.7TT Join Date: Nov 2008
Grossly overpriced. $3175. Should be $995-$1595 option. Car already comes with 4 piston the 6 pistons are a couple of hundred more on ebay.
Ex: my '06 GTO came with 2 piston front 1 piston rear. In 2013 I went on amazon and ebay and did silver 6 piston/4 piston ctsv 2 calipers with 14" camaro SS rotors f and 13.4" z06 rotors rear bohnmann caliper brackets hawk hps pads and a pin kit for $2100!. Prices have gone up n the calpers since then but MSRP of $3175 is ridiculous. When I get my SS I will go to the parts counter and buy the factory GM 6 piston brackets, buy the calipers and pads online and paint the rear calipers red to match. |
10-27-2015, 10:10 AM | #27 |
Drives: 2014 Camaro SS Join Date: Mar 2014
^ I agree on the price, but would like folks to realize that its not just new calipers, it does include new rotors, and a few other bits.
SOLD: 2014 Camaro Coupe 2SS/RS M6 Blue Ray Metallic, NPP, Nav
2014 Stingray Premiere Edition Coupe #142/500 Z51 3LT M7 Laguna Blue, Magride, NPP, Exposed Carbon Fiber Roof, Carbon Fiber Dash, Suede Wrapped Interior Canceled: 2016 Camaro Coupe 1AK37 2SS Coupe, G7E Garnet Red, BRJ Adrenaline Red Trim, F55 Magnetic Ride, NPP Exhaust, CF5 Sunroof, 56R Gray Split spoke w/ machined face, RN2 LPO Illuminated Bowtie, VYW Premium Floor Mats, W2D LPO Cargo Net |
10-27-2015, 03:18 PM | #28 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
If I were getting a Gen 6 SS there are 3 options I consider mandatory.. MRC, NPP and the 6 piston caliper upgrade. Too bad it's not a factory option because it probably would be cheaper and definitely a worthy upgrade. I just don't trust the dealer goons even on a simple brake swap.
