04-06-2018, 10:19 AM | #211 |
Coopers Camaro
Drives: 18 Flex Fuel LTG Join Date: Nov 2016
Nice runs you two !!
04-19-2018, 01:22 PM | #212 |
Coopers Camaro
2018-A8-Bone stock-Factory 20" runflats. Showed about 68 F.
Pretty weak Couple of runs. Find it strange they are both exactly 5.8, but completely different run styles. First run tried boost launching around 2300, just completely shot sideways. Second run just matted the gas pedal, broke loose again halfway through first. How are you guys hooking ? Launching down hill or what lol??
04-19-2018, 01:37 PM | #213 |
603 Camaros
Drives: 2017 NGM I4 1LT Coupe Join Date: May 2012
You know what i'll take a picture of where I do my pulls I only get to do them about 30% of the time for obvious reasons you'll see. The runflats break loose like a mofo cooper. Best I've logged is 4.9s I use the same spot and there is wheel spin everytime the only thing that changes from run to run is wether I get wheel hop with it or not.
MY 2017 I4 CAMARO BUILD JOURNAL | YOUTUBE | INSTAGRAM | 316RWHP - 385 RWTQ HPTUNERS DYNO TUNE | 12.693s @ 105MPH 1/4 Mile |
04-19-2018, 01:45 PM | #214 |
603 Camaros
Sorry for the long wait all updated on first post.
04-19-2018, 02:31 PM | #215 |
Coopers Camaro
I've been playing around with different surface types, and it just lights up the 20's like they were on Geo Tracker wheels..lol.. These were the best 2, both on Interstate surface, and still a significant amount of wheel spin...I will try some other techniques maybe..
04-19-2018, 09:31 PM | #216 | |
Drives: 2019 6.2L V8 SS Join Date: Feb 2018
Drop brake at about 2800 RPM right before it caps with TC off and just let the car fight through me flooring it. No finesse on that run and now my TCM is out as you know, so I can't even test with a little restraint. Soon!
04-26-2018, 07:48 PM | #217 |
Coopers Camaro
Got a bit better this time. Showed about 72 F. Temps have been warmer all week, so ground temp was higher than my previous runs. Left from gas pedal only, this time I just kind of rolled into the throttle, instead of mashing it. Still had a bit of wheel spin towards the top of first, but much better. I think I could hit a 5.2 if I drop air pressure in the rear tires down from 38 psi.
05-19-2018, 01:02 PM | #218 |
2017 A8 I4 - 93 Octane Gas - TC On (whoops)
Mods: CAI, Intercooler + Pipes, Water/Meth Injection, 65mm TB, Hi-Flo Catted DP, Mid & Y-Pipes, Axle-Back Exhaust, Colder Spark Plugs, ZZP PCM Tune, 20x10 rear wheels w/ 305/30R20 NT05s Little bit of slip, forgot to turn TC off while testing the new tires... going to drop the tire PSI to 32 on both sides and see if that's a nice mix of grip and street driveability (I'm sure it will be).
05-20-2018, 02:47 AM | #219 | |
603 Camaros
06-05-2018, 08:14 PM | #220 |
Drives: 2017 Chevy camaro 2.0 turbo Join Date: Jun 2018
My 0-60
I ran 5.5 with my A8 all stock
06-07-2018, 10:56 PM | #221 |
Drives: Sold Join Date: Sep 2016
A8, 20" stock wheel, K&N filter & ZZP tube, Nxtstep muffler.
07-02-2018, 07:19 PM | #222 |
Coopers Camaro
A8, un-finished PCM tune only. 95 degrees after work today, forgot to turn TC off, also forgot sport mode..Oops..
07-02-2018, 07:32 PM | #223 |
Drives: 2016 camaro 2.0t gray Join Date: Apr 2017
07-02-2018, 07:57 PM | #224 |
Drives: 2017 Camaro 2.0 RS Join Date: Jun 2017
Help ?
I was reading your build stuff, I missed where you installed that digital gauge in the far left vent. How has that affected the AC flow? And is it a Turbo Boost Gauge, if not since you seem to know a lot, think anyone make a nice analog boost gauge that would be easy to install?
