![]() Drives: 2016 Camaro 2SS (on order) Join Date: Mar 2016
Weak start (2016 SS)
Took my 2016 SS to the dealer for weak start analysis. They said they ran a diagnostic on the battery, alternator, and starter, but it diagnosed normal.
After I picked up my car, there was a "Test Report" (receipt paper) on the dash with the diagnostic results. It showed this: BAC CODE 171600 Diagnostic Mode Test Info CCA 700 Out of Vehicle Flooded Results Good Battery Rated: 700 CCA Measured: 794 CCA Measured Volts: 12.42 Amp Hours: 0.0 I read around on the forums and noticed "heat soak". I think that might be a factor because it tends to happen after my car is hot and I restart it. It did not do this last Summer, but I'm worried that when it hits 100+ degrees this Summer that it might fail and leave me stranded. Is there a GM bulletin or warranty covered fix for this?
2016 Camaro 2SS Garnet Red
V8, Dual Exhaust, MRC, Nav, Sunroof, Loaded "Ahhh! Take care to get what you like or you will be forced to like what you get!" - Lyrics from a song from Scooter: "Apache Rock the Bottom!" Previously owned 1998 BMW 540 w/M-series package 1991 Trans Am GTA 1985 Saab 900 Turbo (Burned leaded fuel on the Autobahn) 1985 Firebird (R.I.P.) 1976 Camaro LT |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Wife's 14' IS 250 Join Date: Mar 2014
I live in FL, I have the weak start daily.
-11% tint all around Ordered • 2/06/16 Built on • 3/22/16 Adopted • 4/07/16 Sold on 2/05/16: 2014 Camaro SW L99, 2SS, RS, NAV, Inferno Orange Interior: -Borla ATAK catback -Range AFM delete -15% tint all around -Red LED interior bulbs -55k white Cree LED fogs -License plate LED bulb swap -12" Sub Kit, BA amp swap -Oracle ghosted LED sidemarkers |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
With the battery in the trunk would the amount of heat soak really be that much compared to an engine bay? Only askin' as I'm in the south too, haven't had an issue but only had my car 4 months.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
Is this only occasional weak start? I have the same problem.
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
![]() Drives: '17 2SS, NGM, MRC, DPP; '19 F150 Join Date: Apr 2017
雪の玉
#7 |
![]() Drives: 2016 hyper blue SS Join Date: Sep 2014
Same here.. after a good 30 mins of being on when I try to turn it right back on it will sometimes hesitate for even a half second between cranks. Dealer couldn't find anything wrong either
#8 |
Noticed it turns over slightly slower than a on a cold start when the motor is hot. I'm not worried about it.
#9 |
![]() Drives: Hard Join Date: Feb 2016
Heat soak and a slow (... like WAY slow) starter are a well-known peculiarity of this car. Lots of people have reported very slow cranking when engine is hot, but no one—to my knowledge—has reported a failure to start. If it actually fails to start, that would be news.
'16 2SS, 6MT, MRC, NPP, sways, square 285's—and an ear-to-ear grin!
#10 |
![]() Drives: Hyper Blue Metallic 2016 2SS M6 Join Date: Nov 2013
Same here people. I wouldn't too much worry about it unless it decides to not start at all.
#11 |
![]() Drives: 1SS 1LE Rapid Blue Join Date: Apr 2016
This happens to me between autocross runs if I turn the car off. I leave it on now because it's a pain in the ass to remember to put it into track mode then comp mode.
#12 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
I have the same issue with my car currently, but I don't believe mine is related to heat soak. Do any of you have an accessory charger plugged in? I notice that when i leave a device plugged in to the accessory charger with the engine off, even for a few minutes, the starter turns wayyyyyyyy slower. Like the charger is sapping power, or the car continues to supply power even while its off. (enough to quickly drain the battery)
I just completed a long drive from los angeles to san diego and back. traffic on the way down, traffic on the way up. engine was definitely warm, but the starter would work fine if i remembered to remove my accessory charger. 2016 2ss btw, 10k miles
#13 | |
The USB charger? Sent from my iPhone using Tapatalk
#14 |
![]() ![]() Drives: 2017 ZL1 Join Date: Oct 2016
Normal. One of the car mags even commented on it..
My Car Blog and mods. Previous Chevys: 2016 2ss, 2015 C7 z51, 2004 C5 Z06
