05-25-2022, 11:46 AM | #1 |
Drives: Chevy Camaro Corvette Nova Blazer Join Date: May 2022
Flex fuel sensor 2.0l
I installed a zzp flex fuel sensor, is there any way to check if it's working properly. The tune is set for flex fuel. No cel at all and I tested the pink wire and it shows 9-10v?
05-25-2022, 11:54 AM | #2 |
Drives: 1970 chevelle Join Date: Aug 2011
you would need software or a hand held device that reads alcohol content and look at what the sensor is reading and add a know calculated amount and determine what the % should be based on known added amount and what the percent in the actual fuel added is vs how much is in the tank and if the calc works out to 25% and the sensor is reading roughly 25% its working. For instance if you have roughly 5 gallons in tank and sensor is reading 0% alcohol and you add 5 gallons of e85 that is 50% alcohol and your sensor is then reading 25% after a short drive you sensor is working.
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car 2015 Z06 Z07 Daytona Sunrise Orange Metallic Dads Car 2013 ZL1 vin 963 Crystal Red Tint Coat/Black Wheels Exposed Carbon Fiber Insert 6 Spd Manual |
