04-27-2022, 05:07 PM | #1 |
Drives: 1LE Join Date: Sep 2017
Who needs a spare or replacement road race...
Engine!
I will probably get flamed but I only really know this good group of peep! https://www.facebook.com/marketplace...7321180416865/ Condition Used - like new FOR SALE 5TH GEN LT1 LONG BLOCK JUST REFRESHENED AND NO RUN TIME. THIS ENGINE WAS MY “SPARE” FOR MY 2017 CAMARO 1LE ROADRACE CAR. I HAVE ALL RECEIPTS. ALL READY JUST NEEDS YOUR ENGINE COVERS! - Manley 2618 Pistons in 11.7:1 compression -Manley H-Beam Rods - ARP Rod Bolts -Wet sump GM LT1 crankshaft -Texas Speed 229/244 .635/.635 112 LSA 109 ICL + 32% fuel lobe -2116LSR - Johnson Lifters Link Bar -97-TVS-2187P - PAC POLISHED .660 Dual -Chromemoly Pushrods 3/8-Diameter -212-CHETrunion - CHE LS/LT Trunion Kit - 0 Degree Phaser Limiter -DOD Delete Kit -HD C7R Timing Chain by IWIS -GM factory oil pump -GM MLS Head gaskets WORK PREFORMED ON REFRESHED SHORT BLOCK Disassemble Short Block Degrease block, crank, rods Degrease miscellaneous engine parts. Measure Main Bearing Bores and Alignment Measure Bores Measure Crankshaft Main & Rod Journals Balance V-8, Internal TIG weld reluctor to crank Hone V-8 cylinders with plates Wash block for assy or cam bearings and plugs Install Cam Bearings Fit Cam Bearings to cam File End Gaps - 16 Piston Rings Install each Piston Ring Manley Forged Piston Total Seal AP Steel Rings King Main Bearings HP/XP Series King Rod Bearings XPN Series Cam Bearing - Coated Overhaul oil pump, check relief valve, variable vane system Install bearings, measure main & rod clearances, selective fit bearings for proper oil clearance. Assemble LT1 short block, review all dimensions & clearances LT1 CYLINDER PORTED HEADS. NO RUN TIME. -Brand new GM LT1 heads -CNC fully ported -97-TVS-2187P - PAC POLISHED .660 Dual |
04-27-2022, 05:33 PM | #2 |
free freight? if so ill take it haha thanks nicky !!
04-27-2022, 08:45 PM | #3 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
That's a good price for that engine. If anyone does any research at all they will realize that. No flaming is warranted.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
04-27-2022, 08:47 PM | #4 |
Krops, he may take you up on that offer!!! I know LME in Texas can crate pallett ship via truck an engine for about 375.00 from Houston to Dallas because I just paid it.
LOL
04-27-2022, 10:32 PM | #5 |
At 9850 that should sell fast. GLWS!
04-29-2022, 08:47 AM | #6 |
Thanks guys!
Yeah I looked at what engines are going for POST COVID prices and it is nuts! |
04-29-2022, 08:49 AM | #7 |
Texting is cool BTW...
215 3 two seven 0997 |
04-29-2022, 08:54 AM | #8 |
I am really confused on what I want to do too with my Camaro..
Maybe you guys can help me...LOL Should I sell it and buy another platform that has a lighter base weight? C5Z or C6Z? My problem is that I cannot just "go to the track" and do same lap times and be happy. I gotta always improve. 3+ yrs developing this car and I couldn't be happier with it just wish that I could snap my fingers and it drop 500lbs! I just dont think I can go much faster, yeah could be later on the brakes but that is high risk move cause if you over shoot a turn it is hard coming back. Yeah stop buying "take offs" and buy new Michelin slicks and go faster for 1st 4 or 5 sessions while they are fresh but seen the prices of them? Sometimes I think to myself "How many seconds a lap would I loose if my car magically lost 400-500 in between track sessions on a perfect track day?" I gotta believe, not pushing any harder, that the car would go 1.5 seconds a lap faster....and that inlies why I am thinking of selling the car. Last edited by NickyRacerBoy; 04-29-2022 at 09:18 AM. |
04-29-2022, 09:19 AM | #9 | |
OK as far as selling your Camaro, I think that would be a mistake. That being said a 2008 Corvette Z06 at 3132 pounds and perhaps some power upgrades to 5-600 RWHP would make a GREAT track car. Those cars currently can be bought for about 45K. Now I WOULD NOT trade straight up my Camaro for a 2008 Corvette but I have done ALOT of work to make a very good car a great track car. My general feeling is a STOCK 2008 Corvette Z06 with the right tires would go around a road course QUICKER than a stock SS 1LE. Michelin TAKEOFF SLICKS by the way can be bought for about 125 dollars a tire including shipping. https://www.bimmerworld.com/Wheels-Tires/Tires/ You are going to need to get some 18 inch wheels.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 04-29-2022 at 09:45 AM. |
04-29-2022, 10:08 AM | #10 | |
My car is fully caged and all the safety equipment. Trading is for a stock Z would be crazy. Yeah I get them for that price and I have two sets of 18. Stock for stock Z would be faster but this will be max effort roadrace car. |
04-29-2022, 10:14 AM | #11 |
shit ton of work doing cages in these cars.
04-29-2022, 10:24 AM | #12 | |
https://bringatrailer.com/race-car/
04-29-2022, 10:35 AM | #13 |
Drives: 2021 1SS 1LE Join Date: Nov 2020
What would it take to get your car down to say - 3250?
How reliable are those takeoffs? |
04-29-2022, 10:56 AM | #14 | |
If you wanted to BOTH use your car for the track and as a daily driver, 3250 pounds would not be feasible. EMPTY weight now I m probably around 3550. The STOCK SS seats weight around 55 pounds each side and you save only about 50 pounds if you replace those with race seats. But you pick up weight with things like roll bars and seat harnesses. You of course could go hog wild and take off the AC compressor, sound insulation, back seat, passenger seat and use carbon fiber body panels yada yada. I am not sure even THEN whether you could get to 3250. I never went down that path so I cant say ABSOLUTELY that it is not possible.
