![]() Drives: 2021 camaro ss 1LE Join Date: Dec 2020
Attention satin steel owners! -front bumper paint not matching
Hope this is in the right section. Just wanted to give you guys a heads up that GM has agreed to cover the cost of my front bumper to be painted to match the rest of my car. As far as I know, this is a common issue so I hope this info helps anyone in the same situation.
… I just noticed the “issues/problems/warranty” section. Fail.
![]() Drives: 2021 3LT RS Join Date: Dec 2017
That's interesting, since I believe all of the front and rear fascias are painted separately from the rest of the car and won't necessarily match up, particularly in the eye of a detail-oriented paint and body man. (The shop I am working with thought both my 2016 and 2021 had repainted front bumpers, due to the non-matching metallic paints, until I read here on the forums that the bumper fascias come to the assembly line pre-painted.)
Other than the lack of a match for the metallic paint, was there some other problem with the paint on the front fascia? What portions of the car will they be painting and/or blending? While I would like to have front and rear fascias that match up better with the rest of the car, I would also be concerned about potentially ending up with something worse than I started with... Last edited by The Maverick; 01-05-2022 at 03:18 AM. |
SoCal C5 Family Member
Drives: 1996 Z28 SS & 2014 ZL1 Join Date: Apr 2009
All of the plastic pieces (bumper covers, rockers, mirrors, spoilers, etc.) are not painted at the assembly plant like the car body is.
Vance Chula -
1996 Camaro Z28 SS #1688 2014 Camaro ZL1 Coupe #1956 |
Thank you Al Oppenheiser!
Batch to batch variation on metallic paint is common. Also, differences in "flop" of the fleck in metallic paints are common even when painted in the same booth by the same person with the same batch of paint. So even when the color matches, you can get visible differences in shade (and/or color with tinted fleck) depending on ambient light and viewing angle. But this is typically only a concern on high-end custom paint jobs, not something we would normally care about from the factory.
6th gen ZL1 wheels are notorious for huge variations in color due to the nature of the 3 layer paint. For some, G7Q Nightfall Grey Metallic is a perfect touchup match. For others it's nowhere close. As stated by Vchula, because the plastic bits are not painted on the assembly line with the bodies with the same robots and same batch of paint, you will always see some kind of variation. Normally it's not too bad. But when it is, you get what you see in the OPs picture. |
Indeed there will always be a small difference, plastic body parts on my car aren't painted the exact same hue as metal body panels either, but OP's car is in a whole another league, I'm glad GM agreed to repaint the front.
(Interestingly, I have a new front fascia and the doors blended due to a, khm, mishap, but the color match is absolutely perfect with the rest of plastic/metal, respectively, even though the body shop obviously used a different batch of paint, from >12 months later than when the car was built. The color difference on OP's car is way worse than anything I've seen.)
#7 | |
#8 | |
GM uses "Just in Time" delivery and it would be too costly to have piles of parts just lying in a room somewhere just so they can be color-matched to a particular body.
Vance Chula -
#9 | |
#10 |
![]() Drives: Camaro 2020 2SS VERT Join Date: Dec 2020
mine match very well together.
#11 |
![]() Drives: 2018 ZL1 Convertible M6 Join Date: Nov 2019
Also painting plastic and metal can result in color variation between the two, especially in direct sunlight. I believe it has something to do with the metal parts getting ELPO dipped for corrosion protection and the plastics parts not going through that prior to painting. Much more noticeable on the lighter colors (even white).
#12 |
![]() Drives: 2018 ABM 1SS 6M Join Date: Jan 2020
My Arctic Blue car has the same problem, only it’s the rear bumper. It’s super noticeable where it meets the rear quarter panel.
2018 1SS 6M ABM
#13 |
![]() Drives: Chevy Camaro 2021 ,rs, v6, 6 spd Join Date: Feb 2022
I just found this thread. Mine is satin steel. It was built mid-late 2020. I bought it new 1-2-21.I didn't notice the front bumper being diff than rest of car a for few days. Now I don't notice.I have been hand washing it almost weekly and use turtle wax spray every 2-3 months. It seems to have blended.About the 3rd week I had it somebody at work asked me if I had wrecked it.I think op car looks great even with miss match.
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE WCT A10 BCD +PDR Join Date: Mar 2008
My '22 Wild Cherry has the mismatch also. I see this all the time on many vehicles.
2022 1SS 1LE A10 BCD WCT +PDR
2014 1SS 1LE NPP Recaros SIM-(SOLD)-Build Thread:http://www.camaro5.com/forums/showthread.php?t=395103 My Instagram: https://www.instagram.com/roadracing3/ 2010 GMC Sierra 1500 Crew Cab SLE 5.3L-Hauls stuff 2009 Pontiac G8 GT-SOLD 1995 Chevrolet Camaro Z28 5.7L-SOLD http://www.camaroz28.com/forums/cars...-c-lt1-691328/ |
Thread Tools | |
