Old 07-30-2021, 08:55 PM   #1
ABM1SSSG3
ABM1SSSG3's Avatar
Drives: 2017 Arctic Blue Metallic A8 SS
Plexiglass fine scratch remover
Is there an effective product out there to remove fine scratches from the top cover of the GM CAI?
2017 SS Arctic Blue Metallic A8 GM big brake kit SG3 Lowering & Sway Bar Kits
ABM1SSSG3 is online now   Reply With Quote
Old 07-30-2021, 09:19 PM   #2
Trochoidal
Drives: 2017 Camaro 2SS A8
Id suggest this product. We manufacture parts from acrylic/plexiglass. After machining we remove the cutter swirls from the end mill by wet sanding to smooth the surface. After that we polish the acrylic/plexiglass with a very similar product to what Im suggesting. $20 and some of your time and you should be good to go.
I doubt you need to wet sand. If you do I wouldnt use an aggressive grit. If you do need to wet sand Id also suggest getting the 2 hook and loop kit. Maybe 4000 grit to start and keep it soaked.
https://www.amazon.com/Novus-7100-Pl...02UCYRZU&psc=1
Old 07-30-2021, 09:31 PM   #3
ABM1SSSG3
ABM1SSSG3's Avatar
Thank you
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
