07-22-2021, 03:26 PM | #1 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Texas smog?
After doing very little research it looks like only a few counties require OBDII "emissions testing". Can you run LT headers in texas and other modifications and still pass the emissions test? Or will you fail the visual thus causing you to fail the emissions test?
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
07-22-2021, 06:50 PM | #2 |
Drives: Chevrolet Camaro Join Date: Nov 2019
Texas varies by county what specific requires. Mainly If you go big franchise place than they will be more picky and conplaint about everything,you are good to go if you go old pop’s shop
10-02-2021, 09:26 PM | #3 |
Drives: 23 ZL1 24 Tacoma Join Date: Aug 2020
Depends on the county. They are cracking down on the shops that will look the other way. Can't legally pass with LT's but it can be done if you can find a place. My 99Z28 passed with Heads/Cam/LT's but that was years ago.
23 ZL1-A10-Summit White
10-03-2021, 12:06 AM | #4 |
Drives: 2016 Camaro SS Join Date: Jul 2020
Not an issue unless you have codes or monitors not in ready status. I have cam, headers and more with no problem. Car chops really loud last year the shop said I probably had something wrong with my car, it didn't sound right, was too shaky and should have them do the maintenance lol
10-03-2021, 04:30 PM | #5 |
Drives: 2018 Camaro SS 1LE Join Date: Jun 2020
Seems like nearly every Corvette and Camaro is modified in Texas, they're passing somehow. Although, with the shift in color Texas seems to be having that could change in the future and make it much harder to pass.
2002 Camaro SS | 2003 Corvette Z06 | 2008 Corvette| 2016 Corvette Z06 C7.R | 2018 Camaro SS 1LE
10-03-2021, 08:49 PM | #6 |
Oldman w/a teenager brain
Drives: 2022 ZL1 A10 Join Date: Mar 2021
TX is solid Red. We just got Constitutional Carry.
10-03-2021, 09:48 PM | #7 |
