Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 05-09-2020, 07:06 PM   #1
FlyingFischer5
FlyingFischer5's Avatar
Drives: 2019 Camaro 2SS Satin Steel Gray
Which splitter? EOS/Factory
Having a hard time trying to decide which front splitter I should pick.
1.) Camaro RS / SS Front Splitter Lip | ZL1 1LE Track Package
https://extremeonlinestore.com/colle...19144445427779
2.) Camaro Front Splitter Lip | 6th Gen Camaro Facelift 1LE Package
https://extremeonlinestore.com/colle...29490691637315
I'm leaning toward number 1 for a couple reasons. It seems a bit larger and lower which could mean more air forced through the bumper. Also like how its raised in the middle to keep air flow going to the cooler that is located under the front and lower on the sides and also the larger side wings on it.
As for the second I like how it has the 2 sharp points on it. Makes it look a little more aggressive. The only downside(for me) is that it seems like this is the most popular one to go with aftermarket wise and is also a factory option which would make the car more of a cookie cutter car and not a car that stands out from the rest.
Wanted to get all your opinions on both of these and the build quality difference between the two. Any pro/cons of each if any of you have them.
Thanks
2019 Chevy Camaro - 2SS - Satin Steel Gray Metallic - RotoFab w/Dry Filter and Sound Tube Delete, (2) Banks iDash Gauges in ZZP Pillar Mount, DD Side Marker Lights, EOS Gloss Black ZL1 Splitter, Ikon Gloss Black Rear Diffuser
2004 Chevy Trailblazer - LS 4.2l - Black - 3.5" Lift, Custom Interior, Custom Roof Rack and Grille w/Built-in Light Bars, 285/55R20 on Trailblazer SS Wheels
FlyingFischer5 is offline   Reply With Quote
Old 06-11-2020, 10:29 AM   #2
ember1205
Hot Camaro
ember1205's Avatar
I've ordered a splitter and skirts in what they call "Refresh Style" which is at least similar to the second one. I actually want a very flat overall style and I managed to get the full kit for under $500.
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
