Old 12-23-2019, 04:39 PM   #1
TheDamme94
Drives: 2016 D1X Procharged Black 1SS
Help with methanol mounting
Does anyone have any tips on installing methanol injectors on a silicone procharger pipe. Im having a hard time finding any info searching google. Alky controls instructions are super vague when it comes procharger assemblies.
TheDamme94 is offline   Reply With Quote
Old 12-23-2019, 08:22 PM   #2
Kerry
Drives: 2019 2SS Camaro
Just did mine its not to bad. I started with the uni bit from the start then went with a bit. I made the hole on the small side and pushed the nozzle in. take off the rubber washers compleatly. You dont use washers at all. Push it through then use a little blue locktight carefuly. I used a qtip to dab it on. Then tighten snug.
Kerry is offline   Reply With Quote
Old 12-23-2019, 08:44 PM   #3
Kerry
Pixs
Old 12-24-2019, 06:21 AM   #4
TheDamme94
What size did you drill the hole to on the unibit? And what bit did you step to after that? Never mounted a kit with this setup and i wanna get this right the first time and not order another pipe haha
Old 12-25-2019, 04:39 AM   #5
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Metal pipe
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 12-25-2019, 07:45 PM   #6
Kerry
I went to the 5/16 or about .303 thou. Then used a .340 thou bit. It was an exteremly tight fit. I wanted it to be snug and it was about all i could do to push it through the hole. I think the rubber will always be smaller than what you drill just the nature but like you I wanted to be on the extrem safe side.
Old 12-26-2019, 10:48 AM   #7
TheDamme94
Sweet, one less thing that im shooting in the dark for, with the yellow MAP/MAF wire how did you connect to the trigger wire for your MAF/MAP, did you splice into the factory harness?
Old 12-26-2019, 03:45 PM   #8
Kerry
No my alky control kit came with a 2 bar sensor
Old 12-26-2019, 08:14 PM   #9
danhr
BAMF SS
danhr's Avatar
Did you get the map kit or MAF kit?
Stock Longblock
Old 12-26-2019, 08:22 PM   #10
Kerry
map
Old 12-26-2019, 08:35 PM   #11
danhr
BAMF SS
danhr's Avatar
The question was directed to the OP, because he shouldnt be touching the yellow wire for a MAP based kit.... you only use that for a MAF kit. Dont know why you would use a MAF kit on a procharged car, but I dont know everything.
Stock Longblock
Old 12-26-2019, 10:34 PM   #12
TheDamme94
Okay thats what i was confused about. The instructions i recieved for my kit were for a Roots supercharger alky kit. I ordered the centrifugal kit so it should come with the 2 bar as well. I saw instructions about tapping into the trigger wire and got confused
Old 12-27-2019, 12:18 AM   #13
danhr
BAMF SS
danhr's Avatar
The instructions that come with the alky control kit have directions for both MAP systems and MAF systems.... he just prints one out and sends them out with both, and assumes the installer knows what kit they bought.
So in the end... dont use the yellow wire
Stock Longblock
