02-26-2019, 06:29 PM | #1 |
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Track Number Suggestions?
I would like to get a set of vinyl or magnetic track numbers for my SCCA time trial in May. What do you folks recommend? (I searched, but the results were bad)
02-26-2019, 07:38 PM | #2 |
Drives: 2018 ZL1 coupe Join Date: Nov 2018
03-07-2019, 09:41 PM | #3 |
Because Racecar!
large roll of magnet sheet and some stencils from amazon. just under $40 all in with enough material to make lots of sets.
They have held on over regular 120MPH straights. |
03-08-2019, 07:04 AM | #4 |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
↑↑↑ I'd still run a strip of painter's tape along the leading vertical edge(s).
Alternatively, you could run just the cut-out numbers (and if you're more artistic than I am, use the tape for visual effect). Norm
'19 WRX 6M (the family sedan . . . seriously) |
03-08-2019, 09:21 AM | #5 |
Drives: '17 SS 1LE Join Date: Jun 2017
+1 for trackdecals.com. I have a set of magnetic numbers from them and have never had an issue at >140mph.
03-08-2019, 10:33 AM | #6 |
aka BeastZL1
Any paint swirling or scratches from the magnetic numbers?
Sent from my iPhone using Tapatalk Pro
03-08-2019, 01:10 PM | #7 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
He uses a stronger than average magnetic backing for track decals. You can also customize to your hearts content.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
03-08-2019, 01:11 PM | #8 | |
Wipe the area down with detail spray before you put on.
2017 HBM SS 1LE
03-08-2019, 01:46 PM | #9 |
I put 6" numbers on the quarter windows. www.pegasusautoracing.com
'17 ZL1 A10 Mosaic Black PDR/Nav 2:03.08 VIR Full 11.003@129.2 1.75 (sold) '15 Z/28 #325 Black a/c & stereo. 2:10.1 VIR Full (sold) '12 ZL1 A6 Black 10.52@131 1.55 60' 2:13 VIR Full (sold) Last edited by Stephen12ZL1; 03-12-2019 at 06:05 PM. |
03-11-2019, 09:29 AM | #10 |
03-11-2019, 10:10 AM | #11 |
Drives: 2017 Camaro 1SS, 2023 Colorado Z71 Join Date: Sep 2017
+++1 for Track Decals, also confirmed stayed on at 140+, no negative impact to paint
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow |
03-12-2019, 02:03 PM | #12 |
Drives: Tracks: 18' ZL1 1LE Join Date: Mar 2018
It will scratch. Happened to me so I switched to vinyl and left them on.
18' ZL1 1LE Red Hot track toy
Castrol SRF Ported TB/Rotofab dry intake AWE Track w/PLP APR GTC300 wing / Singular Endplates ASC Splitter / PA tunnels MFR Engineering Custom Diffuser Race Louvers Fender Vents APEX SM10 & ARC8 For sale: 2018 OEM ZL1 1LE Wing 12' Nissan GT-R SOLD |
03-12-2019, 07:35 PM | #13 |
aka BeastZL1
Bummer. I bought the magnetic ones from Track Decals after the positive reviews. I'll clean them as suggest and see how it goes. My car is far from a car show queen.
03-12-2019, 08:51 PM | #14 |
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Dec 2016
I have had great luck with https://www.firestormgraphix.com/
Magnetics should not scratch if you take proper care. I make sure the surface is clean first. I carry wax and a micro fiber just for that purpose. I also make sure that I wipe off the magnetic side before I put it on so there is not grit between surfaces. Finally, I never drag the magnetic side off the car. I roll it on and peel it off. Separately, I never had one come off, but you can tape the leading edge if you are concerned.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG etc.. |
