11-24-2018, 07:41 PM | #1 |
Need additional brake cooling
I've seen the SS camaro has some pieces of plastic to add on the front suspension for track days.. Does this part fit on the SS 1LE?
If not... Has anyone done brake cooling improvements on the 1le? I'm thinking of getting ducting from the front "ducts" directly to the rotor center. Context: I boiled Motul RBF600 brake fluid my first time out. Let me know what you think! - Thanks
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
11-24-2018, 08:22 PM | #2 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
I have heard of people boiling Motul but have not heard of Castrol SRF boiling.
Sesrch if you can. I think those cooling things do work. |
11-24-2018, 10:50 PM | #3 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
Yes you can bolt on the SS Camaro front ducts to the SS1LE.
How much better they are is not known. A few people here run them and I will be running them as well. |
11-25-2018, 01:14 PM | #4 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
Are you sure you boiled the fluid? You can also get brake fade if the pads haven't been bedded (within 2 days of the track or so) and fully heat cycled.
Every time I go to the track, I re-bed the brakes to get a nice blue transfer layer on the rotors, let the brakes cool overnight. Next day they are SOLID with RBF600, even at Laguna Seca. Past 20 minutes though, I have to take one or two cool down laps. |
11-25-2018, 03:06 PM | #5 |
Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
something seems weird here. Back in the summer I went all day in 70-80 degree weather on RBF600 without a problem. I wasn't pushing super hard but I was having fun and definitely getting the brakes nice and hot. What track were you at? Ambient temperature? What pads? How old is the fluid? Humidity?
11-25-2018, 08:30 PM | #6 |
I have ran the SS brake duct cooling kit, which includes larger ducts and smaller splash shield, cost $15. I figured I'd try them for the Texas heat. I switched back to the stock ducts for the cooler days and I'm glad I did.
I use SRF and stock pads and never had a problem even at COTA in the summer. if you're using a more aggressive pads that could be the source of your heat. |
11-25-2018, 09:56 PM | #7 |
Drives: 2017 Camaro 1LE Hyper Blue Join Date: Apr 2017
Another factor may be what settings you had on the PTM. There is a lot of rear brake intervention in the Dry setting. I use Motul and haven't had it boil with stock pads and tires.
11-25-2018, 10:42 PM | #8 |
That was my second thought, is what driving mode is OP using.
See if you overheat with it on PTM race |
11-25-2018, 11:31 PM | #9 | |
Drives: 2018 SS 1LE Join Date: Sep 2018
11-26-2018, 08:39 AM | #10 | |
Drives: 2017 SS 1LE Join Date: Mar 2016
IG: @NC_M1SS1LE
11-26-2018, 10:02 AM | #11 | |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
https://www.camaro6.com/forums/showt...2#post10327912 You're running ST-43 pads, which lack the thermal backing plate and put significantly more heat into the pistons than stock pads. Of course you cooked the calipers and the fluid, you're missing the thermal plates. When I ran ST-43 pads with J6M brakes, I cooked the front calipers too. You need Ti shims, no exceptions.
11-26-2018, 10:05 AM | #12 |
Hot Dog
I knew the OP's name and this topic sounded familiar. I told you how to fix it months ago, and you didn't listen. Ready to fix the problem yet?
https://www.camaro6.com/forums/showp...2&postcount=17
11-26-2018, 10:11 AM | #13 | |
Boom there you go OP! haha ok potentially stupid question inbound, I pan on going to the Hawk DTC60s in the spring, do those have the thermal plates or will I need to buy some shims as well? I'm no brake pad expert haha
IG: @NC_M1SS1LE
11-26-2018, 11:04 AM | #14 |
Imo if you can fit TI plates do it.
The more thermal contact resistance there is between the rotor and the caliper the better. And do not use any grease on the pads (quieting) as that will aid in moving heat to your caliper. |
