Old 09-03-2018, 08:51 PM   #15
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Originally Posted by LiqTenExp View Post
Do you have photos of where and how much you took off?
If you do a search, there are a number of threads with good pics. I can try to dig some up, but, if you look at NINETRES pic with the inside wheel lip near the strut with his hand there, that's where you clearance. I found the above pic from another thread. You can see where you have to clearance depending on what negative camber you end up with.
RUQWIKR is offline   Reply With Quote
Old 09-03-2018, 09:35 PM   #16
This is exactly what I wanted to do on mine and didn't want to go with knock-offs. They look great on your car and great job on the ceramic coating.
I'm surprised the fronts poke a little with no spacer. I guess there is a couple degrees of offset difference.
Great thread!!! (I fixed the pics)
Old 09-03-2018, 09:49 PM   #17
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Thanks for the edit. But wait, I’m running a spacer. Do you mean they poke without a spacer because they appear to poke more than 5mm?
ninetres is offline   Reply With Quote
Old 09-04-2018, 07:35 AM   #18
Trans damm
Drives: Trans am
Its amazing how much better the car looks with 19" rims.
Trans damm is offline   Reply With Quote
Old 09-04-2018, 03:29 PM   #19
Squatch
Camaro pilot
Squatch's Avatar
Drives: 69 Camaro, 2014 ZL1
how much is the speedo off from the 19"?
2014 ZL1 Camaro
1969 Camaro
Squatch is offline   Reply With Quote
Old 09-04-2018, 04:19 PM   #20
Chris Edwards
Drives: 2017 ZL1
Agreed. I think they look even better with 18's!
Chris Edwards is offline   Reply With Quote
Old 09-04-2018, 07:45 PM   #21
ninetres
ninetres's Avatar
I barely drove around the block so any difference wouldn’t be obvious at low speeds like that. I think there is a difference in overall tire height....although small, so the speedo would be slightly off at higher speeds (because it’s a percentage difference, not flat speed difference).
Old 09-04-2018, 08:10 PM   #22
Nevermind... I thought the spacer was only in the rear. I forgot these wheels were 1" wider in the front too.
I have a second set on order and will put some DRs on the rear for the streets. MT makes a 325/30-19 that should work great.
Old 09-04-2018, 08:22 PM   #23
Trans damm
Drives: Trans am
I did 19’s on my Z. I would of went with 18’s but won’t fit with the carbon rotors. I don’t think these cars look right with 20’s. If I end up buying a ZL1 I will have a drag pack waiting for it.
Old 09-04-2018, 08:25 PM   #24
ninetres
ninetres's Avatar
I’m ONLY running a spacer in the front. None in rear.
Old 09-05-2018, 06:04 AM   #25
SliChillax
SliChillax's Avatar
Drives: Camaro ZL1 A10, F-Type R, RR Sport
How much has the ride comfort been improved?
SliChillax is offline   Reply With Quote
Old 09-05-2018, 06:11 AM   #26
Biscuit.fr
Drives: Red hot ZL1 A10 2017
Has anyone tryed to cut the extra metal on the MRC according to this picture?
(To clear the 19 tire)
Biscuit.fr is offline   Reply With Quote
Old 09-05-2018, 06:22 AM   #27
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Many (many) people. Easy to do with an angle or die grinder.
Old 09-05-2018, 06:37 AM   #28
Biscuit.fr
That was I was thinking, no need for spacer, just cut!
Any software adjustment for Dic speed between 19 and 20?
Any difference between std Zl1 and 1LE?
If not which one is right?
19 right with 20 slightly above
20 right with 19 slightly below
