04-23-2018, 06:57 PM | #1 |
ported throttle body and warranty?
I was looking into the Tony Mamo ported throttle body mainly for the throttle response people talk about gaining especially with the M6. My question is will this void my warranty?
04-23-2018, 10:43 PM | #2 |
Drives: 2017 SS Hyper Blue Join Date: Jan 2018
Keep thit old one if your really worried and swap them if you have to take it to the dealer, but you can’t even tell otherwise unless you actually pull off the intake tube.
04-23-2018, 11:16 PM | #3 |
A ported throttle body will not void your warranty. The dealer would never even notice it's ported. We have had a lot of success running V-Max systems.
04-23-2018, 11:55 PM | #4 |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
If push came to shove, and your engine was damaged, and you didn’t replace it with the stock one before dropping it at the dealer......they absolutely could point to the TB being tampered with, causing an alteration in the intended metered airflow. You’d be proper ****ed. That’s IF they notice it. And IF they want to be assholes.
Like mentioned, keep the stock one handy to avoid this possible issue. |
04-24-2018, 12:34 PM | #5 |
Thanks guys! is there any possibility of it throwing codes?
04-24-2018, 02:21 PM | #6 |
No codes with mine.
04-24-2018, 02:34 PM | #7 |
Drives: 2018 SS 1LE Join Date: Sep 2017
I understand matching the mating surfaces for smooth transition, but what are the real gains? we talking 5 HP or what? I would love to get my LT1 to have 100 more HP and still be able to pass mandatory emissions testing here in AZ. Trade up to a ZL1 is not an option here.
04-24-2018, 04:23 PM | #8 | |
04-24-2018, 05:14 PM | #9 |
I would contact Pray Performance and get both the Throttle Body and Intake Manifold ported. 15-17whp gains across the board.
2016 NFG 1SS A8
Thread Tools | |
