Old 05-11-2020, 09:42 PM   #71
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
SM10's and 305 30 19 SQUARE set up
OK Here are some pics of SM10's along with some pics of the actual weight of the SM10 with MS 4S 305 30 19 mounted including TPS sensors (53.4 pounds). Another pic shows the STOCK 2019 SS 20 x 9.5 wheel and MS 4S 285 35 20 mounted WITH TPS sensor (55.8 pounds) and ALSO the front Stock SS wheel 20 x 8.5 and GY 245 40 20's with TPS sensors (55 pounds).
Notes: the setup you see DOES NOT require a 5MM spacer because part of the strut mount was ground down about 6MM to allow for proper clearance. Negative camber is 1.5 degrees on EACH wheel and that for the most part eliminated the top tire poke (see pics).
The suspension is STOCK SS WITHOUT MAG RIDE. Wheel gap is roughly 2 inches currently which will be reduced to roughly 1.25 inches when the SG3 suspension is installed. This is the WIDEST rotatable combination that can be run currently on an SS. Ground clearance is roughly 6.5 inches in FRONT of the rear wheels and 5 inches in the BACK of the front wheels.
The 305 30 19 tires mounted on the 19 x 10.5 rims give you roughly 11.5 inches of rubber on the ground (section width is of course wider to the tune of about 12 inches). It is doubtful you could run a wider tire on the front without having alot of top tire poke regardless of how much negative camber you used.
Black gorilla locks were used and the stock APEX wheel cap was painted a satin black to match wheel. A big shout out to AMP (clearancing), APEX (quick delivery and superb support) and DISCOUNT TIRE (no installation damage).
I added the last pic showing where AMP modded the strut to get the necessary clearance. It doesnt take much here about 6MM.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 05-17-2020, 10:01 AM   #72
davidwarren
Drives: 2019 SS 1LE
Arc-8 in 19x11 camaro spec. I had to use a 3mm space in the front to clear the mag strut because I already had camber maxed at the strut and some more with plates (3* total). Kinda surprised at how I set the rears are, might have gone with the 12s if I had known.
https://imgur.com/a/CmXtIgM
davidwarren is offline   Reply With Quote
Old 05-18-2020, 06:03 PM   #73
cirpower
Drives: Camaro ZL1
Hi Apex, is it possible to run a 305-30-19 on the 12 inch wheel? cheers cirpower
cirpower is offline   Reply With Quote
Old 05-18-2020, 06:26 PM   #74
sr71bb
sr71bb's Avatar
If you refer to the MICHELIN website the recommended wheel size range to run with a 305 30 19 tire is 10.5 to 11.5 inches. Having said that it is not uncommon for people to run a half inch narrower or wider than recommended rim without issues.
Retired Cars BELOW:
Old 05-21-2020, 12:17 PM   #75
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
Here are the APEX ARC-8 in Matte Bronze 19x10 all four corners with Michelin Pilot Sport AS 3+ 285/35-19's on my 2019 ZLE.
warren3537 is offline   Reply With Quote
Old 05-28-2020, 12:39 PM   #76
APEXRaceParts
APEXRaceParts's Avatar
Drives: Camaro Z28
It is possible yes, but to be honest I wouldn't simply because there are enough 325 tires available that fit well on the 12" wide wheel. You'd just be carrying around a little extra weight running a 305/12" combo vs 305/11".
Phone: 925.245.0773 | experts@apexraceparts.com
Website | Instagram | Facebook | Blog
APEXRaceParts is offline   Reply With Quote
Old 05-29-2020, 07:16 PM   #77
APEXRaceParts
Drives: Camaro Z28
More SM-10 goodness on Cem's gorgeous new SS 1LE.
Front: 18x10.5" ET22 wrapped in 295/30-18 Toyo RR, 5mm spacer to clear the MRC dampers
Rear: 18x11" ET44 wrapped in 315/30-18 Toyo RR
- Cory
Old 06-06-2020, 12:38 AM   #78
MTSS1LE
Drives: 2007 C6 Z06
Just got my SM-10's mounted
Here are the specs:
19X10.5 ET22 Square with 5 mm spacer up front
ZL1 1LE DSSV 2.7/2.0 Camber F/R
Hankook RS4 305/30/19
MTSS1LE is offline   Reply With Quote
Old 06-07-2020, 03:56 PM   #79
Cherry
Drives: 2017 SS 50th
Damn how much of a difference did those dampers make?
Cherry is offline   Reply With Quote
Old 06-08-2020, 02:54 AM   #80
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Some photos from track days
18x10.5" ET22 Front (5mm spacer + knuckle grinding mod with -2.8 front camber) -315/30/18 Toyo RR tires
18x11" ET44 rear - 315/30/18 Toyo RR tires
APEX ARC-8 WHEEL 19X11" ET11 (front - OEM ZLE fitmet) with GY Supercar 3R - 305/30/19
APEX ARC-8 WHEEL 19X11" ET43 (rear- OEM Camaro SS fitment) with GY Supercar 3R - 305/30/19 - for SQ setup
APEX ARC-8 WHEEL 19X12" ET41 (rear - OEM ZLE fitment) with GY Supercar 3R - 325/30/19 - for staggered setup
glamcem is offline   Reply With Quote
Old 06-08-2020, 10:11 AM   #81
1LE76G
Drives: 2017 SS 1LE
Originally Posted by APEXRaceParts View Post
Some 5th Gen Racecar action from the boys over at Famous Racing, rocking 18x11" EC-7s wrapped in Pirelli slicks
Will these wheels clear the OEM ZL1 1LE brakes?
1LE76G is offline   Reply With Quote
Old 06-17-2020, 04:52 PM   #82
APEXRaceParts
Drives: Camaro Z28
Yes they will! In fact, we just had Woman Driven put a set on her ZL1 1LE this past weekend.
18x11" ET25 front and rear, 1/2" spacer with extended studs up front for strut clearance. Wrapped in 305/680 Pirelli DH slicks
Cory
Old 07-29-2020, 05:35 PM   #83
APEXRaceParts
Drives: Camaro Z28
This beautiful Procharged ZL1 built by PRE Racing just got a wheel and tire upgrade to handle all that power!
Front: 19x11" ET11 with 305/30-19 Goodyear SC3R
Rear: 19x12" ET41 with 325/30-19 Goodyear SC3R
- Cory
Old 07-29-2020, 06:48 PM   #84
20Bluezl1
- Cory
Planning on running a group deal anytime soon?
Copyright ©2000 - 2023, vBulletin Solutions, Inc.
