06-07-2017, 10:47 AM | #1 |
Toyota Tech
Drives: 2SS A8 Join Date: Jul 2014
Nitrous window switch install help
From the wiring diagram is askg me to tap into the tps wot input wire and the rpm or tach input wires. Any help to location of the 2 wires would be great.
2016 Camaro SS A8 Roto-Fab CAI: Drag set up 11.9 @116
Sold 95 Camaro Z28 Cam:Bolt ons: 12.3 @114 Sold 2013 Chevy Crzue LTX |
06-07-2017, 05:43 PM | #2 |
Drives: Camaro 17 SS Join Date: Jan 2017
06-07-2017, 06:19 PM | #3 |
For mock up and testing purpose you can use a green wire from your ignition coil for RPM, and for pedal position you can use the yellow and black wire coming from your pedal. Im trying to find the wires I used from the connector. I will update you when I find them.
06-08-2017, 08:15 AM | #4 | |
Toyota Tech
06-08-2017, 08:18 AM | #5 |
Toyota Tech
Started install last night
06-08-2017, 06:40 PM | #6 |
Did you go with the full nitrous outlet kit? I like their window switch. The ability to delay activation based on gear is pretty nice.
11-21-2017, 10:11 PM | #7 |
Drives: SRT4, 2ss Join Date: Nov 2016
Hey, which wire did you end up using for rpm signal?
The green wire from the ignition cool? |
11-22-2017, 08:33 PM | #8 |
Bump
11-27-2017, 06:02 PM | #9 |
Hey guys, any help is appreciated. Does anyone know which wire to use for rpm signal?
11-27-2017, 06:49 PM | #10 |
11-27-2017, 07:53 PM | #11 | |
Thx for the response btw. |
11-27-2017, 08:01 PM | #12 |
No worries bro. Its just that nitrous threads don't get much love on here that's all.
