![]() Drives: Camaro Join Date: Apr 2010
Carbon Ceramic Brakes for G6 ZL1
Are you looking for a CCM brake setup like Z28 but can not have that option when you order your ZL1, or you like it but think it's too expensive to afford or run/maintain.
RaciingBrake can help. This will be a new system converting your stock iron to CCM by re-using your stock front calipers, swapping your stock rear caliper to Z28, and we will take care of CCM rotor design and builds. We will design and make the required rotor hats, assembled with RB hardware. The CCM discs will be exactly the same as Z28 (394x36mm front and 390x32mm rear.) so no problem in future disc and pad replacement. We have both Z28 calipers and CCM discs (front and rear) in stock, and we also carry brake pads (for street and track). Let's know if this is something you are are interested. |
C.O.T.W. 10-27-2014
How much would a set up like this cost roughly?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Man, the tech side of me is drooling just thinking of how sexy a set CCB would be on a 6th gen Camaro, then the frugal side of my cringes at the thought of the $1500 each price tag that the rotors carry to replace them when the time comes.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
ooh, i like
I used to be Dragoneye...
I'm....listening.
![]() Estimated price? |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
Would make for a nice track only spare setup with a set of dedicated pads.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
Hello, I have my listening cap on. Drum roll please........ the price is right
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
#8 |
I found this for some sort of reference. Looks about $10k+++
https://www.racingbrake.com/category-s/7373.htm
Current ride
#9 |
We propose to build the following CCM brake kit for ALL Camaro G6 upgrade.
http://www.camaro6.com/forums/showth...ht=racingbrake Last edited by RacingBrake; 04-17-2017 at 01:46 PM. Reason: Add link for brake bias analysis |
#10 |
![]() Drives: 2017 ZL1 Join Date: Nov 2016
THE PRICE. WHAT IS IT.
2017 Camaro ZL1
Instagram: @ZL1_Tommy Youtube: ZL1 Tommy |
#11 |
#12 |
RB Rear Hat.
![]() OE Rear Hat. ![]() RB rear composite hat (aluminum alloy shell w/Iron sleeve for emergency brake) weighs only 43% of OE (made of stainless steel) - 4.5 lbs per rotor (9 lbs per axle) is highly significant in unsprung weight reduction. Reviews on Corvette Forum.
#13 |
ZL1 OE two piece rotor weight:
#14 |
Front RB-CCB Rotor for ZL1 Upgrade with an estimated weight of 14 lbs. Directly bolt on to OE spindle, and fit right under OE 6-pot caliper and save 16 lbs/rotor or 32 lbs/axle over OE iron rotors.
Thread Tools | |
