07-06-2017, 09:18 PM | #29 | |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
You can still link the images by getting a URL from the pics you attached to put them inline just an fyi |
07-06-2017, 09:33 PM | #30 |
Scientific negotiator
Drives: 2019 Grand Sport Join Date: Mar 2017
Awesome THANKS. I'll do thhat tomorrow. I've hit the lazy wall for the night!
2019 Grand Sport M7
2018 ZL1 1LE 6MT 2017 SS 1LE 6MT . Matthew 25:40 ΜΟΛΩΝ ΛΑβΕ |
07-07-2017, 02:57 PM | #31 | |
07-07-2017, 06:15 PM | #32 |
Yeah my apologies, it's been an insane few months at work, but let's talk about these pads...
STREET Performance (Grade B+): First off how do they perform? From a street use perspective they are great. They have a little less bite than the brembo pads, but certainly not an issue at all for street use. These pads will stop the car in a hurry, and will continue to no matter how hard you use them in any reasonable street setting. Compared to ceramics I have used on the C7, C6, C5 (yes, I have issues with cars that start with a "C") they work excellent. I've spent WAAAAAY more money on pads that don't feel any better than these do. They bed well, and the bedding lasts long. I recommend them for the street. I heated them up as much as any reasonable street drive would be able to, and there was no issue at all. These are in no way track pads, but they worked great. DUST PERFORMANCE (Grade A++): This is where these pads really shine. They literally never dusted, even from break in. I go an incredibly long time between wheel cleanings with these pads. AMAZING performance there. There are no pads that dust less than these that I have ever used. Perfect. Even 1521's didn't dust less. TRACK PERFORMANCE (GRADE N/A): I did not and do not intend to use these on a track. There are certainly better pads for them, even from Powerstop that are compatible with these. Since they are so easy to swap I will just swap them back and forth like I used to do with the C5Z. Overall I'd absolutely buy these again. For the money it is shocking how little they dust. Love them. Hope that helps a little!
2019 Grand Sport M7
08-10-2017, 12:32 PM | #33 |
Drives: 2000 GMPPSV SS & 2017 ILE SS Join Date: Jul 2017
Thanks for this great write-up. I just can't stand the brake dust anymore! Just ordered my pads and the 22mm socket from Amazon. The pin is out of stock... bummer. I'll make my own.
08-10-2017, 12:48 PM | #34 |
Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
Do any of you guys know the bleeder torque spec?
08-10-2017, 06:38 PM | #35 | |
13lbs... (from C7Z) ----------------------- Specs stolen from the corvette forum... If they are right, you are welcome. If they are not it's all on you... Fastener Tightening Specifications Brake Caliper Bleeder - J56 Front 13-15 lb ft Brake Caliper Bleeder - J56 Rear 106 lb in-12 lb ft Brake Caliper Bleeder - J57 Front and Rear 13-15 lb ft Brake Caliper Bolt - Front 162 lb ft Brake Caliper Bolt - Rear 89 lb ft Brake Caliper Bridge Pin Bolt 22 lb ft Brake Hose Fitting Bolt 30 lb ft Brake Rotor Bolt 106 lb in Front Brake Shield Bolt 89 lb in
2019 Grand Sport M7
11-29-2017, 07:20 PM | #36 |
Fixed the pics (mostly). Still a little lazy tho
2019 Grand Sport M7
03-15-2018, 10:20 AM | #37 |
Going to do this soon, once the weather breaks and my 1LE wheels go back on. It looks like you used the new clips that came with the pads. I've seen aftermarket clips rust really fast... would be inclined to reuse the GM set if changing them isn't 100% necessary. Any input on that?
03-15-2018, 11:24 AM | #38 |
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel Join Date: Oct 2017
Yeah, brake pad changes are easy. I actually bought the little pin punch tool to prevent chipping the caliper powder coat. I used the Powerstop pads. On the street, no noticeable difference in braking but a huge difference in brake dust. Almost zero dust. I also took the opportunity to clean the calipers, suspension, and inside of the wheels.
03-18-2018, 08:12 PM | #39 | |
03-18-2018, 09:18 PM | #40 |
They're stainless steel.
03-18-2018, 09:42 PM | #41 |
Drives: 2018 SS 1LE Join Date: Apr 2017
Great write up. I've used Powerstop in other applications and have liked them. I'll save the OEM pads for the track. Will be nice not to have to clean the wheels on regular basis.
03-19-2018, 12:51 PM | #42 |
Drives: 2018 1SS 1LE Join Date: Sep 2017
Thanks for the great write up! This is something I will probably do this spring.
Thread Tools | |
