Old 03-02-2016, 03:52 PM   #1
bseiter98
NPP squeaking noise
Just started up my SS and noticed a fairly loud squeaking noise when going from the Tour mode to the Sport mode. It only lasts for a second or so. Anyone else have this problem? The temperature is about 30°F currently, I do not recall hearing this when it was warmer out. Thanks!
bseiter98 is offline   Reply With Quote
Old 03-02-2016, 04:16 PM   #2
jimmypop13
Drives: 2016 camaro ss
I had a very loud chirp when switching from v8 to v4 mode on my first NPP. My new one doesn't do it. I'd take it to the dealer if it bothers you enough. They may replace it
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 03-02-2016, 04:18 PM   #3
bseiter98
Thanks Jimmypop13, I will do just that when I bring it in for my first oil change.
Old 03-02-2016, 04:39 PM   #4
Netslave
GM paint evaluation dept
Netslave's Avatar
Drives: Too many to list
Anything like this?
http://www.camaro6.com/forums/showth...exhaust+rattle
Co-owner of Tony the Tiger
- A GM factory custom orange and mosaic black striped 2016 SS 2SS
- U̶n̶o̶f̶f̶i̶c̶i̶a̶l̶l̶y̶ Officially the worst Mosaic Black paint on a 2016 Camaro SS 2SS
See him here -
https://drive.google.com/folderview?...3M&usp=sharing
Netslave is offline   Reply With Quote
Old 03-02-2016, 04:52 PM   #5
bseiter98
Originally Posted by Netslave View Post
Nope, just a quick chirp...
Old 03-02-2016, 05:17 PM   #6
Zultain7
Zultain7's Avatar
Drives: 2016 Camaro SS
Mine did the same thing, just a little chirp noise. Its the set of valves closing in the exhaust. I spoke with my dealer and they said they have never heard of it before and most likely something with the valve is loose or build up has caused the clearances to be too tight.
Hyper Blue 2SS Auto, Duel Mode Exhaust, MCR, Nav, Black 5 Spoke
Ordered on 8/29
2000 Status on 9/1
3000 Status on 9/3
3300 Status on 10/8
3400 Status on 10/9
3800 Status on 10/19
Delivery 12/28
Zultain7 is offline   Reply With Quote
Old 03-02-2016, 06:48 PM   #7
jimmypop13
That's my car. They replaced that system with the revised green dot system. Still doing the same though. Someone is coming to look at it on Friday so we will see what happens! The chirp sounds like a bird. It happened on mine with the upstream valves during the v4-v8 transition. The new system did fix this
Old 03-15-2016, 05:31 PM   #8
bseiter98
Appointment with Dealer on Monday, will let all know what comes of it!
Old 03-21-2016, 05:14 PM   #9
bseiter98
Had the appointment with Dealer... Their instructions were to grease it so they did. Got home, backed in by garage and put the car in tour mode. Squeak is now louder than before. Frustrating!
Old 03-21-2016, 09:36 PM   #10
raptor5244
Drives: 2022 CT4-V Blackwing
Sounds like the squeeky NPP has been going on for a while since the system was introduced in the corvette.
http://www.corvetteforum.com/forums/...es-in-npp.html
http://www.corvetteforum.com/forums/...on-of-fix.html
http://www.corvetteforum.com/forums/...le-squeak.html
The NPP in my GEN5 is different than the stingray and new Camaro. Only manual trans had the option for NPP since they don't have AFM. Furthermore the valves are vacuum based not electric like they are on the stingray and gen 6 Camaro.
Old 03-29-2016, 04:23 PM   #11
bseiter98
Update - Returned the car to the Dealer today and they reviewed the issue with GM Engineers. I guess they measured the loudness (SPL) of the squeak and it was decided the best course of action was to replace the exhaust system. I do not have the details yet as to what they ordered as I doubt it was the entire exhaust just the sections with the NPP valve. Anyway, just wanted to provide an update.
Old 03-29-2016, 07:51 PM   #12
Bitchin' Camaro
Bitchin' Camaro's Avatar
Drives: 2016 Camaro 2SS Mosaic Black/Black
Just adding this for others with a similar issue, since it sounds like the dealer has evaluated yours and come to a service action.
This applies to a squeak when changing modes, not the issues some have with a rattling valve that is constant or at least appears in a certain rev range. There is a TSB to cover the squeak when changing modes. It was originally for Corvettes but amended to cover the 2016 Camaro thru Dec 15th builds.
2016 Camaro 2SS
Mosaic Black/Black, Low Gloss Black 5 spokes, Dual Mode Exhaust, MagRheo Shocks (GB8 56V NPP F55)
http://www.last.fm/music/The+Dead+Mi...in'+Camaro
12/14/15 Dealer processed order
TPW 1/25/16
1/21/16 Built and Bayed
1/28/16 At the dealer
1/29/16 Took delivery w/ 3 miles on it
Bitchin' Camaro is offline   Reply With Quote
Old 03-30-2016, 03:15 PM   #13
bseiter98
Thanks, I had heard about a TSB but never actually saw it until you posted it.
Old 05-24-2016, 08:49 PM   #14
ReFLeX135
ReFLeX135's Avatar
Drives: 2017 Camaro 1SS
Just curious, how did this turn out for you? Currently mine chirps from v8 to v4, squeaks while driving at random times, and rattles in all modes. They might be replacing my exhaust but I'm not sure yet. They don't believe me about the squeak or the AFM chirp and called it a "click" form the transmission gears changing =/ I removed f51 and the squeak stopped but not the rest ofc.
Hyper Blue | A8 | NPP Dual Mode Exhaust
ReFLeX135 is offline   Reply With Quote
Copyright ©2000 - 2023, vBulletin Solutions, Inc.
