05-27-2020, 09:27 AM | #43 |
Drives: 2018 ZL1 1LE Join Date: Aug 2017
I put Nitto Invo's on the ZLE and though it hasn't been tracked with them. I've been very happy with the grip and the ride on the street. Haven't noticed any road noise with them either. I'll definitely use them again.
05-27-2020, 01:41 PM | #44 | |
Drives: 2016 Camaro SS in Red Hot Join Date: Apr 2016
05-27-2020, 01:43 PM | #45 |
05-27-2020, 02:37 PM | #46 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
There's a significant decrease in tire life using the stock runflats (and most runflats) when compared to non-runflat tires though.
Nobody gets a car with 20" tires that are over 9" wide and thinks the tires are going to be cheap. But it's not unreasonable to have the assumption that the tires wont be bald after 2 years if you're not burning out in them. Normal (boring) driving should get you 40k miles at least before having to replace tires. That's simply not the case with the stock runflats. Spend the money and get the AS3's. You wont be disappointed. They'll perform better, be quieter, and last massively longer doing the same kind of driving as the runflats. |
05-27-2020, 03:03 PM | #47 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
I think the biggest thing you're missing is the ability to rotate. All the warranties for the tires state the warranty is halved if the tire sizes are different front to rear.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
05-27-2020, 05:35 PM | #48 |
I'm leery of not getting run-flats, I guess. I realize there are kits you can get to reinflate a flat tire, but I don't know how well they work.
05-28-2020, 12:21 PM | #49 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Yep another BS call by the MFGs we have to live with. Especially since you can go left to right. So it is not a real rotation but still moving them. If the wear is even they should honor. But i am at their mercy.
05-28-2020, 12:26 PM | #50 | |
Dry traction is okay, wet roads after 5k miles can feel like ice. |
05-28-2020, 12:52 PM | #51 |
Run flats are HEAVY and expensive, there's lots of options of thing you can carry in the trunk and they work fine, this isn't new stuff. Also I learned after owning a vette, carry the business card of your favorite tow truck company, I hit a piece of steel on the highway and it ripped my oil pan open.
05-28-2020, 12:59 PM | #52 |
The money you save by not using runflats can easily cover whatever tow truck cost that isn't covered by your insurance and whatever tps damage you may cause due to using fix-a-flat if you go that route.
It's literally over 500+ dollars saved by getting the AS3 over runflats over the course of the AS3 lifespan. You basically double the lifespan of runflats. If you're doing more than 500 dollars worth of flats in the same period, then maybe it's time to move. |
05-28-2020, 01:57 PM | #53 |
Appreciate all the advice. I weighed all of it, and believe it not, I got another set of the OEM tires. I'd forgotten how great the car feels on new tires.
05-28-2020, 02:00 PM | #54 |
They're still on the driven axle.
'16 Camaro 1SS
05-28-2020, 02:00 PM | #55 |
*flips table
'16 Camaro 1SS
05-28-2020, 02:06 PM | #56 |
