02-07-2021, 08:28 PM | #43 |
Drives: camaro 1SS Join Date: Aug 2019
question I have when you disconnect the cluster you said disconnect the usb... so when you buy that blue usb cable one end to the hud other to cluster??? in the pic I can see the other usb plug.. Where does both of the usb plugs go
02-07-2021, 10:53 PM | #44 | |
Drives: 2017 ZL1 Vert - M6,SIM,CFW,NAV Join Date: Oct 2014
If you're referring to the LVDS USB cable, then yes.
2018 2SS Vert - Hot Wheels - Indy 500 #30 2017 ZL1 Vert - M6 , SIM, CFW, NAV 2017 RS 1LT 2.0T Vert - A8, Garnet Red - SOLD :-( Added - IO6 - NAV, UHS - Enhanced Display, K4C - Wireless Charger, UV6 - Heads-Up Display - DIY 2011 CTS-V - Black / Black - SOLD. :-( 2013 ZL1 - Black / Black - SOLD. :-( 2010 2SS - Indy 500 Pace Car. - SOLD. :-( 2002 Z28 - Pewter / Black - SOLD. :-( |
02-08-2021, 06:06 PM | #45 |
thank you for the fast reply.. i understand I buy the blue usb one end goes to hud other goes to the back of the cluster.. in the posts it says to unplug the usb and the gray harness.. in this pic shows the usb conn. (w/ black plug) where does that go?? I hope I dont sound like a dumb ass
02-08-2021, 06:37 PM | #46 |
To be fair, I traded that vehicle for my 2018 2SS Hotwheels Indy 500 Car. If I remember correctly, the end that goes into the cluster is similar to a mini USB connection. There is only 1 spot in the back of the cluster that it would fit.
02-08-2021, 06:47 PM | #47 |
after this one i give up lol in the pic there is 2 usb connections.. one it the blue wire that goes from the hud to the cluster.. the first usb connections that you unpluged when you took out the cluster where does that plug go.. (the one on the right side of the pic. black wire black plug)Again thank you for your help
02-08-2021, 07:05 PM | #48 | |
02-08-2021, 07:20 PM | #49 |
im going to do it to my car. may by 5 videos but going to youtube it. thank you for the info... know its a old post
02-09-2021, 07:11 AM | #50 |
Nice. Hope the information helped out. It was a nice project.
04-09-2021, 08:09 PM | #51 |
Drives: Chevy Camaro ZL1 Join Date: Oct 2020
05-14-2021, 02:31 PM | #52 |
Drives: Chevrolet Camaro Join Date: Apr 2019
Gen 6 HUD Retrofit
Have everything needed to get my 2017 Chevrolet Camaro V6 1LT RS to have iO6, HUD, Spectrum Lighting on radio, cup holder, door trims, footwell, door sills, plus, enhanced 2SS cluster, and all GM oem new parts and accessories.
Only problem I foresee is wiring harnesses or splicing harnesses. Willing to buy official harness and replacing. Okay if costs $500. Will I need to add an amp or okay as is (without amp)? Last but not least, only thing that is added is an extra footwell lighting for cup holder wire. But if needed for radio, probably not needed if I get wiring harnesses, etc... So I’m only worried about harnesses and or having to splice wires (don’t want to splice the wrong one. And 5Gen DIY cluster upgrade wire doesn’t have hud retrofit attached or this shit would be easy. But Gen5DIY says they are working to add a HUD retrofit pigtail to cluster add on wire they list for $192 and cents. |
05-15-2021, 01:06 PM | #53 | |
06-16-2021, 07:20 AM | #54 |
Drives: Various! Join Date: Jun 2021
Excellent thread! Are the 2019+ cars any different for this retrofit? I am planning this for a 2021 Camaro LT1 Coupe that came with the Technology Package (Bose 9 speakers and the 8” screen). I am getting the IOT swap plus upgraded cluster set up for HUD, both from White.
I retrofitted Night Vision into a late-model BMW so adding wires to existing connectors is ok by me. However, if a loyal vendor out there is offering a pre-made harness or a kit I’d be glad to patronize them.
Djcwardog
2021 Camaro LT1 MN6 WRS Package. GJ1 (Shadow Gray Met), H1T (Jet Black interior), NPP (Dual Mode Exhaust), Y3W (Tech Pkg), 5JX (20” black satin split-spoke wheels). Upgraded from IOS to IOT Radio. Hooker Blackheart No Crush Kit. Retrofit UHS Cluster and HUD. Last edited by djcwardog; 06-20-2021 at 06:12 AM. |
06-16-2021, 07:32 AM | #55 | |
06-16-2021, 07:36 AM | #56 |
www repair procedures dot com has a subscription based service. You could pay for a day and download as much as needed. Or maybe find a PDF online of the full manual.
Thread Tools | |
