TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 10-15-2019, 05:06 PM   #1
bandier
Got mine!
bandier's Avatar
Drives: 2021 LT1 RS - Orange Crush
stock SiriusXM antenna with aftermarket head unit
Can it be done? Use a stock SiriusXM antenna with aftermarket head unit??? I'm being told I have to buy the aftermarket SiriusXM tuner and antenna. If the new head unit is SiriusXM compatible, why cant I use the stuff that's already in my car? Please educate me.
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
bandier is offline   Reply With Quote
Old 10-15-2019, 06:18 PM   #2
Cheap Guy
Cheap Guy's Avatar
Drives: 2011 Camaro SS
You just have to buy a converter or if you’re super cheap you can modify the existing connector. It should work.
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold
Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current
Cheap Guy is offline   Reply With Quote
Old 10-17-2019, 01:54 PM   #3
bandier
Got mine!
bandier's Avatar
Any idea where to get a converter? So it's just a connector issue? Is the connector modification difficult? Hmm, if I gotta buy something else, I might as well buy the Sirius Tuner and antenna. I was being cheap and hoping to save the $70.
Old 10-21-2019, 12:20 AM   #4
rotwiler
ruff ruff
rotwiler's Avatar
Drives: 2010 2SS/RS
If all you need on a aftermarket Hu is a antenna, then it will work. The Camaro has a fakra plug, even if you have different color fakra, you can remove the plastic cover on the fakra plug and will just plug in like a rca(under cover is simular to mini rca) . I did this on my Ram truck when I put a newer year 8.4 radio in. Antenna is a antenna as long as it's for the service your using. I don't use sat radio now. But a lot of radios now you have to buy a seperate sat radio tuner. Most sat antennas I have seen are fakra, one in Camaro pretty sure is violet, but like I said pop off the plastic cover on the fakra and will plug into Any fakra there is. They just color code them for specific setups, my colors didn't match on my Ram truck but works fine and I get sat traffic alerts and the free stuff with zero issues.
2010 2SS/RS, XO Verona wheels, BC coilovers oem ZL1 bumper conversion Kenwood ddx9905s, maestro, Kenwood xr1s, xr4s, kappa 1200w,subs, Kenwood xr comps and rear deck speakers, long tubes, hf cats, speed secrets tune, custom exhaust, CAI, blacked out everything.
rotwiler is offline   Reply With Quote
