11-22-2017, 01:00 AM | #1 |
Drives: 2018 Camaro 1SS Join Date: Jul 2017
2018 SS catch can needed?
car has about 400 mile on her now, is this something i should have, will the 16-17 models fit the 18. thanks in advance
11-22-2017, 01:40 AM | #2 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
Wow. This has never been discussed before. /s
11-22-2017, 01:59 AM | #3 |
Drives: 2016 Hyper Blue 2SS Join Date: Feb 2016
Yes get one and yes they'll fit the 2018's.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune Upcoming Mods: |
11-22-2017, 04:27 AM | #4 |
Drives: 2014 Cyclone mustang Join Date: Feb 2016
Stops "blow by" needed for sure. UPR rules!
2014 Cyclone/Select Shift/"/Sold
2016 ruby red GT w/3.55:1/resonator delete X- pipe/UPR catch can/Airaid "tube"W/AEM/J&M/BigWorm/BMR /SVE /ZL1addons/Redline/Steeda/BG fluids/ |
11-22-2017, 08:59 AM | #5 |
Drives: 2017 2SS Join Date: Jul 2017
I'd recommend it.
I've been seeing around 2oz of oil in the catch can when i check it (every 3k miles) If you're planning to keep the car less than a few years then it doesn't really matter |
11-22-2017, 11:05 AM | #6 |
Drives: None Join Date: May 2017
2017 HBM SS 1LE | EE Catch Can | Gm Clear tails | Rotofab CAI | DD Smoked sidemarkers | StainlessWorks Catback
11-22-2017, 11:41 AM | #7 |
no catch can here 23k full bolt ons and tune and no problems its up to you...
11-22-2017, 01:48 PM | #8 |
Drives: 2017 Summit White 2SS Join Date: Jan 2017
no catch can with 15k miles here. havent seen any problems but my valves probably look like shit
Follow me on IG: @lip_stick.ss
11-22-2017, 03:43 PM | #9 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
I've caught about 80ml of nasty dark oil in 5K miles with my E2 from Elite Engineering.
Catch cans have a definite benefit with direct injection engines IMHO. |
11-27-2017, 09:27 PM | #10 |
thanks guys, just ordered one.
11-29-2017, 12:28 AM | #11 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
You don't need it. The factory oil separator is actually a superior design to the aftermarket offerings. The only thing that could improve the factory unit is to add a filter/regulator on the separator side of the PCV intake tube (the large middle one) that limits draw to something between 5-10psi and provides a secondary layer of moisture lock without tripping the factory evap monitoring.
The aftermarket cans which don't have an open flow back to the oil pan actually run at a much higher static pressure that keeps the oil suspended in a mist until the vehicle cools or shuts off. And a metal can body will cause humidity to be pulled back in through the intake pipe and condensed into water within the can. A plastic catch tray with a more stable operating temperature is better than metal rapidly heating and cooling next to the exhaust manifolds. Because the factory unit has less pressure and lower temperature variance than aftermarket off-board cans, there is less chance for blow by. A simple check valve doesn't do any real good when the valve still allows it to open without a post valve moisture filter. For any oil separator system, that should be the next evolutionary feature that gets developed. Currently there is no off the shelf regulator/filter small enough to easily place inline of the intake tube that will maintain such a low, fixed psi rating -- just making the filter would be easy. Last edited by JaxChris; 11-29-2017 at 12:46 AM. Reason: Shortened response so people didn't glaze over |
11-30-2017, 07:06 PM | #12 |
@SS_1LE
Drives: 2017 SS 1LE Join Date: Mar 2017
I catch 2-3oz of oil every time I check it in mine as well (Mishimoto). Probably not necessary but it clearly keeps your valvetrain cleaner.
17' Camaro SS 1LE | PDR | Summit White
Borla S-Type Axleback | Mishimoto Catch Can | LED Sidemarkers | ZL1addons DRGs | Michelin MPS4S |
12-17-2017, 02:00 PM | #13 |
Drives: Camaro Join Date: May 2016
Would this catch can reduce any smoke in the exhaust. On start up ?
12-18-2017, 06:29 AM | #14 |
Drives: Too many to list Join Date: Dec 2011
