11-18-2017, 05:29 PM | #15 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
How are you going to do the cam? Pull the motor or remove the front of the car?
11-18-2017, 06:47 PM | #16 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
I'm pulling the motor. I've read that leaving it in is possible but it's difficult to see one of the timing marks.
That being said the engine is all ready to come out, just waiting for my brother to come help me out tomorrow to help guide it and keep an eye out for things I may have missed. Does anyone know what the size the bolts are? I forgot to grab one. The bell housing bolts aren't going to be long enough for my engine stand.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
11-19-2017, 07:05 PM | #17 |
I made no progress yesterday. I was too chicken to go back out to the garage in 26° weather and start a fire.
Since I don't have anything to vacuum the ac system, I'm unbolting the compressor and hanging it out of the way. There's 2 bolts up top, a stud that has a nut on it, and the stud itself comes off with a 5mm iirc. The one on bottom is very slow going unless you take the sway bar out, which I opted not to do. Other than that, a bunch of electrical connectors, ground wires and some motor mounts. I'll post pics when it's out to show the motor mounts. There's 7 or 9 bell housing bolts,(not certain atm) all but one are easy to get to. The 1 just needs a wobble extension. Wobble extensions are a must for this project!!!! I have needed them several times. Hopefully Thursday at the latest I'll have the engine out and on a stand.
"Spitfire" 427ci
11-20-2017, 08:54 AM | #18 |
Drives: Me: '16 2SS yellow, Wife: '16 1SS Join Date: Feb 2016
awesome! You will love it! Love the power\sound of my camm'd 'maro
- Dennis Hixson
2016 Camaro 2SS ** EdelBrock E-Force Supercharger, 3" pulley, RotoFab air intake, Alky Methanol Injection System, Corsa Extreme Exhaust, Kooks longtube headers, TSP VV2 CAM, 1LE wheels @ 285/30/20 front & 305/30/20 rear... 707.41rwhp, 702.36 torque |
11-21-2017, 02:14 PM | #19 |
Drives: SS 6 speed of course Join Date: Jan 2016
looking forward to the write up. There are other engine that the timing marks are hard to see, sometime the fix is as simple as marking the chain with white, red and blue hash marks and not paying any attention to the factory mark...
11-21-2017, 05:49 PM | #20 |
That totally slipped my mind. But it still may be difficult to apply the rtv sealant while it's in the car. But once I get the out I'll put a how to together that hopefully makes more sense than the notes I have right now
"Spitfire" 427ci
11-23-2017, 12:15 PM | #21 |
Drives: 2017 1ss m6. Blue..... Join Date: Mar 2017
You cannremove the engine with the heads on right?? Also do you have to remove the headers completly ?
11-23-2017, 12:30 PM | #22 |
Drives: 2016 2SS Join Date: Jul 2016
Yes you can, and no you don't have to.
11-23-2017, 12:33 PM | #23 | |
I unbolted them, removed the heads then took the headers out of the bay. Just undo your 02 sensors, and gently lower them as far as you can until the heads are out (without scratching if your coated, or snagging wires or hoses)
"Spitfire" 427ci
11-24-2017, 02:32 PM | #24 |
It's out and I hope there's a better way. I had to drop my motor mounts to get the engine in there a little lower, then drop the tranny. (M6). Then i could take my motor. Hopefully there's an easier way. Lol
"Spitfire" 427ci
11-24-2017, 04:02 PM | #25 |
That must be an M6 thing. The motor comes right out on the A8's. You have to remove the motor mounts but they are easy to get to.
11-24-2017, 04:06 PM | #26 |
That's what I'm thinking. That twin disc clutch makes it a little trickier. I could get about 2 inches of gap between the engine and trans, but my oil pan would hit on the k member. Pulling the trans backwards was the only way I could. Very jealous of you a8 guys rn. Lol
"Spitfire" 427ci
11-24-2017, 04:20 PM | #27 |
You mean you removed the trans crossmember/brace/ mount, what ever the proper term for it is, its just 4 bolts and you lowered the trans??? If so thats not toooo bad, i actually installed bmr motor mounts on my car, there way smaller and easier to install / remove. So i know how that is.
11-24-2017, 05:40 PM | #28 | |
