02-27-2021, 04:15 PM | #1 |
Drives: 2022 Vivid Orange Metallic LT1 Join Date: Mar 2020
Code P06DB
Had this code come up last night. Did some research here on the forum and found exactly what it was.
02-27-2021, 04:30 PM | #2 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
What was it? Blue paint?
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top. |
02-27-2021, 08:56 PM | #3 |
The belt wore through the wiring that is there.
02-28-2021, 11:12 AM | #4 |
Here are more pics of the problem and the fix. Cut the wires, solder back together. Tape connections, heat shrink, put loom back on and tie wrap out of the way.
02-28-2021, 06:12 PM | #5 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
Why didn’t you have the dealer replace the harness?
03-01-2021, 04:55 PM | #6 |
1. It is part of the whole engine harness, would not get replaced.
2 Don't trust dealership to mess something else up. 3. Was able to drive my car without waiting. |
03-01-2021, 05:06 PM | #7 |
Drives: 2018 ZLE Join Date: Feb 2018
Good catch. I don't blame you for fixing yourself.
03-01-2021, 05:37 PM | #8 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
Excellent catch on your part. I totally agree with your decision to just fix it yourself. So what does that code tell you?
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
03-01-2021, 05:39 PM | #9 |
Drives: 2019 ZL-1 Join Date: Feb 2009
Thats come up before....
2012 Yukon XL Denali w/ 6.2 AWD |
03-01-2021, 07:22 PM | #10 | |
2) OK 3) I get that, I do. I personally would rather have a new harness & wait than one that’s been repaired, even if it was by me, & I have done a lot of soldering in my time & made my own stand alone EFI harnesses from scratch. Only now your almost new car has an issue & they find that, they will more than likely give you a very hard time. |
03-01-2021, 08:34 PM | #11 | |
P06DB Engine Oil Pressure Control Circuit Low Warning comes on that says "Engine Reduced Power". I did not notice any change in power though. Check engine light went out after the fix. |
