01-31-2021, 08:46 AM | #1 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
What Oil Filter?
Do you only run these? Curious because of the Oil Thread.
6.2L V8 Engine (this includes the ZL1 also, out of the high performance supplemental manual) GM = 12640445 ACDelco = PF64 For a funny read the description... https://www.amazon.com/ACDelco-PF64-...2104379&sr=8-2 |
01-31-2021, 08:48 AM | #2 |
I use a Mobil 1 and Napa Gold on my ZL1 and have had good results!
01-31-2021, 08:50 AM | #3 |
Drives: Chevrolet Camaro Join Date: Jan 2021
That is what I have been running, but I will switch to a Fram Ultra Synthetic which is my usual go to filter. It has the right bypass pressure and is a very good filter for the money. I usually get them at the people’s republic of Walmart. It is the only Fram product that I will use.
I will also run a Napa gold in it (if Convenient) which is really a wix filter. From what I understand it actually filters better than the platinum. Last edited by GrayLT1; 01-31-2021 at 10:42 AM. |
01-31-2021, 09:38 AM | #4 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
I use toilet paper crammed unto a re-useable can. If I get a good paycheck. I might spring for Brawny. That dude makes some tuff paper towels that really clean!
01-31-2021, 10:45 AM | #5 | |
Drives: 2016 2SS Convertible Join Date: Oct 2017
Currently I am trying a PF63E on my Camaro. A little larger cannister with more filter media and it has the correct BPV setting of 22 psi. And even with the larger cannister, it doesn't hang down so low as to be a concern. I am using a Wix WL10290xp on my Z06. I eventually plan to go 100% Wix after I figure out which version I want to use. --KLG--
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
01-31-2021, 11:46 AM | #6 |
Whatever Chev recommends for 0W40.
'20 ZL1 1LE A10,
01-31-2021, 04:39 PM | #7 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
Just in case anything really stupid should happen, I will run the PF64 as recommended to keep any warranty intact.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
01-31-2021, 04:43 PM | #8 |
01-31-2021, 06:19 PM | #9 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Here's more detail: https://gmserviceinsights.com/new-ac...d-performance/
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
02-01-2021, 10:17 AM | #10 |
Drives: '18 2SS/EU (+Recaros) M6 Red Hot Join Date: Nov 2018
****. Now I feel like an idiot having ordered 10pcs last time. Parts are not readily available here, and when import taxes and fees are paid, regular service items end up being quite expensive. So I try to plan ahead ordering as much as I think I’ll need.
02-01-2021, 10:25 AM | #11 |
D3RPZILLA
I'm running ACDelco PF64 Professional Engine Oil Filter (OEM Part Number 12696048).
Website: z1lla.com | YouTube: youtube.d3rpzilla.com YouTube Playlists: Performance Mods | Interior & Exterior Mods | Other Mods |
02-01-2021, 10:25 AM | #12 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
If you bought PF64s I wouldn’t sweat it. The chances of one of those filters creating a catastrophic failure is very highly unlikely.
02-01-2021, 10:26 AM | #13 |
And it is made with Human Hair!
02-01-2021, 01:48 PM | #14 |
I blindly use whatever PF64 Amazon shipped me last time there was a rebate, the notice of which I read in this forum. I think the filters ended up being less than $2 each.
One thing I have learned here is that you can always use the cheapest filters and you should change your oil no sooner than 30,000 miles. I guess that's 2 things. |
