01-08-2021, 02:48 PM | #1 |
Drives: 2019 Chevrolet Camaro Join Date: Sep 2019
Genuine GM Splitter
Does anyone have this splitter? 2019 CAMARO FRONT SPOILER OR FRONT FASCIA EXTENSION, BLACK, LS, LT, RS AND SS MODELS - it Part # 84116168 from shopchevyparts.com
how does it install? quality piece? Thanks in advance B |
01-08-2021, 02:55 PM | #2 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
I originally ordered that splitter thru chevy for my 2020 SS. Decided the one from EOS looked pretty much the same for less than half the money, granted I had to paint it. Sent the chevy part back.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
01-08-2021, 03:47 PM | #3 |
Drives: 2019 Camaro 2SS manual Join Date: Feb 2020
I went with the 2nd gen version (part#84132662). I did not do the install though, I had the dealership do it.
The part is very sturdy and looks great. They should be made with the same materials so I would imagine the part you are looking at is just as good. |
01-09-2021, 11:46 AM | #4 |
Hot Camaro
I have the EOS one as well, but I have not painted it (at least, not yet).
01-09-2021, 11:55 AM | #5 |
Drives: 2019 Camaro 2SS Join Date: Aug 2020
ACS Gen II splitter painted 1LE black. They may be the GM splitter mfg, had a GM logo and everything. Looked OEM.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
01-11-2021, 10:26 AM | #6 |
does anyone have the item I specified?
How does it install? What is the quality? Brian |
01-11-2021, 12:05 PM | #7 |
I’ve had the gen 1 splitter since late 2018. The install is pretty straight forward and quality is standard for an OEM part. It’s held on with rivets/double side tape so you don’t need to worry about it flying off while you drive.
01-11-2021, 09:12 PM | #8 |
Drives: 2019 1SS M6 Join Date: Feb 2020
I installed mine with no help... A few bolts, rivets, and two sided tape..Quality was great.. Paint was flawless, fit and finish was spot on...My PPF installer wished I brought it to him before the install so if you're going that route you might want to check..
1st Gen ground effects kit GBA black , GM CAI , Velossa Ram Air, Expel PPF, illuminated door sills, Upgraded door panels with spectrum lighting
01-12-2021, 08:35 AM | #9 |
Thank you guys
Brian |
01-12-2021, 02:29 PM | #10 | ||
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
https://www.camaro6.com/forums/showthread.php?t=516368 |
