Old 07-29-2020, 09:24 AM   #29
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
Originally Posted by MatthewAMEL View Post
I called. Warehouse has them.
Website says this...
Order now, available in 3 - 5 days at My Store
Maybe it's saying something different for those that have a local DT brick-and-mortar store available to them. Because for the online version (discounttiredirect.com) it doesn't say that. Also, their website says the tread depth for the RT660 is 6/32", which is wrong. The Falken site says it is 8/32". That's important for those trying to run this in classes that require a minimum 7/32" depth, such as SCCA Street classes. For being such a big company, DT's website is kind of a dumpster fire.
Matt Miller
2020 SS 1LE
Msquared is online now   Reply With Quote
Old 07-29-2020, 10:48 AM   #30
DemonZL1
199
DemonZL1's Avatar
Drives: like a granny
Tire rack says no ETA on the 305 and no info on the 315 as of now.
2023 Silverado LZ0 Duramax
2021 Shock SS 1LE A10
www.youtube.com/@DemonWorksPerformance
Anderson composites coupon code : Demon
DemonZL1 is offline   Reply With Quote
Old 07-29-2020, 12:43 PM   #31
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
issue is discount tire is falkens main retailer. the only reason TR has falkens is because of the SCCA SSC class.
they will get them just discount gets first dibs
#53 F Street
2022 Sponsor autocrossdigits.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
2022 Rapid Blue 1SS 1LE
2019 D Street national champion (2019 civic Type R)
apexit53 is offline   Reply With Quote
Old 07-29-2020, 10:23 PM   #32
DemonZL1
199
DemonZL1's Avatar
Thanks for the info !
I am in the market for tires for my car, I have until the end of the month of August to get some 200tw. I really wanted the 315 but i'm considering trying out this 305 on the car.
Old 07-30-2020, 12:22 AM   #33
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
Well, the local store took my order. I'll post when they arrive.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 07-30-2020, 07:44 AM   #34
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Curious as well ,since I am eyeballing the 305 and 315 in 19" size.
ing for grip.
http://www.motorsportsne.com/
Old 07-30-2020, 11:58 AM   #35
Mountain
Mountain's Avatar
So I ran the 285 RE71 R at the last event i was at.
Ill say this, cornering response was sooo good! Lateral grip in some of the sweepers was noticeably lower but not to a determent. at least thats what i thought.
the 295 rt660 has my eye for the front! Not only cause its just a little wider than the 285 but also cause the tire shops wont hate me when i bring them to mount lol
You ran 285/35 front and 305/30 rear (26.8" diameter front and 26.2" rear)?
In RT660, you'd run 295/35 front and 305/30 rear (27.2" diameter front and 26.3" rear)?
Old 07-30-2020, 12:17 PM   #36
apexit53
apexit53's Avatar
unless it messes with the computers too much i dont think it would be an issue.
realistically id like to go 305/315
#53 F Street
Autocrossing Videos
Old 07-30-2020, 12:53 PM   #37
Msquared
Msquared's Avatar
Right, if those sizes come out they are approved for 10" and 11" wheels per Falkens recommended rim widths.
Matt Miller
2020 SS 1LE
Old 07-30-2020, 12:56 PM   #38
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i dont see 19s or 20s on tire rack am i missing something? lol
Old 07-30-2020, 01:04 PM   #39
Scargoes
Scargoes's Avatar
Drives: 2018 Hyper Blue 2SS 1LE
305-19s are available thru America’s Tire. As it was explained above, AT is the main distributor for Falken so they get first dibs. Kinda like Tire Rack and BFG Rivals. I’m waiting for the 315s.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track
Scargoes is offline   Reply With Quote
Old 07-30-2020, 01:27 PM   #40
foshjowler
foshjowler's Avatar
Drives: 2017 Camaro 2.0T, 91 Miata
Also known as Discount Tire in some regions
305 BFG Rivals FTW
Youtube Channel
foshjowler is offline   Reply With Quote
Old 07-30-2020, 01:52 PM   #41
Mountain
Mountain's Avatar
IDK, man, you're the champ with auto-x, but a 1" difference in diameter (0.5" difference in ride height)... on a car that is factory set with a slight rake, down towards the front and that has a neutral/slight-understeer balance and you change that rake to favor opposite... I mean, if it works - it works... but I'd be more inclined to do 295/35 all around. I know, from a braking standpoint, and track driving, knowing the SS 1LE is front biased in bakes by a good amount (I've tested it), I'd try to stay as close to equal in diameter or smaller in front for as much of a rake towards the front as I could. But maybe that 0.5" isn't enough to really amount to anything. Just my thoughts
Old 07-30-2020, 03:37 PM   #42
apexit53
apexit53's Avatar
sometimes you just gota test things so see if they are faster. im not saying it will work, im just curious
#53 F Street
Autocrossing Videos
