Old 02-24-2021, 03:42 PM   #1
Chickngeorge
Drives: '18 RS 2.0t
2.0t front brembo caliper conversion ??
I have a 2018 2.0t RS with the standard brakes...what would I have to buy in order for the FRONT 4 piston brembos to fit?
Also...do the 6 pistons require more than the 4 pistons or the same?
Thanks!
Chickngeorge is offline   Reply With Quote
Old 02-24-2021, 08:11 PM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Depends on the type you buy, there’s 2 types of 4 Piston brembos that were made. LT which uses the same rotor size as the single piston and SS which uses larger rotors.
If you got a LT 4p kit then all you need is the calipers, banjo bolts/washers and maybe caliper bolts.
The SS kit would need all that as well as the larger rotor size.
I’m probably missing something but that’s off the top of my head.
The 6 Piston uses a even larger size rotor but essentially the same as above.
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Old 02-24-2021, 09:39 PM   #3
lcd550
lcd550's Avatar
Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert
To get an idea of what's involved with upgrading, here's a link to the Chevy Brembo Brake upgrade. This link includes instructions as well.
https://accessories.chevrolet.com/pr...tegoryId=98070
I believe you can probably find kits from ZZPerformance, Phastek, or other sites for cheaper.
lcd550 is offline   Reply With Quote
Old 02-25-2021, 04:24 AM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Goto corvetteforum and look for a 6 piston setup there’s a guy got a set in red front, rear, calipers, rotors, and pads for 1250 I bet a grand would buy them!
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
