04-25-2020, 05:04 PM | #15 |
I've installed this today, thank you very much Trochoidal for the install guide. Went through the radiator cover and dropped the hood latch without detaching the front bumper, which is a nuisance whether or not the wheels are removed.
Fitment is very good, it took a while to wiggle this plastic concoction into place, but once it's there, one can see that it'll do its job fine and won't go anywhere. Looks good, too. The test drive didn't show any power or other difference, which was to be expected. Maybe a bit more of intake sound via the Roto-Fab, but it's hard to tell, the placebo factor is real (heh) and the difference, if any, is not striking. I will do some cooldown velocity testing once the weather reaches 80-85°, since that's what I have data logs from and I'd like the comparison to be fair. One small tip: I put a strip of one-sided molding tape on the section that butts up to the diagonal crossbeam so the air duct wouldn't rub directly against the paint or slip away, given the bolts can't be tightened too much, this thing is just plastic.
04-25-2020, 09:25 PM | #16 | |
I logged no less than 3 pulls per modification before coming to any conclusions. So what I noticed as I logged each modification, was the RPM drop between gear changes became less. My take away is the car was being “driven” more as the lag between gear changes decreased. It’s fair to say that explains the MPH increase especially since I wasn’t where I should’ve been “mechanically” at the top of 3rd gear. The A8 has a maximum 3rd gear MPH of 87 at 6210 with the tires I have on the car now and at the time of logging. As you can see from my first log MPH wasn’t 87. My car was that much of a pig! Source used for calculations. https://www.blocklayer.com/rpm-gear.aspx
04-25-2020, 09:28 PM | #17 | |
I’ll take a look at that diagonal crossbeam and give it the same attention. Thanks for the tip.
04-26-2020, 12:39 AM | #18 |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
I installed mine tonight as well, if was fairly easy and straightforward besides doing it at night with little light.
Hood latch wasn't too bad, I actually losely installed it (as lose as possible) before the the radiator cover so that the bolts were already in place. I didn't read your write up on this thread, read one of the other ones and I forgot to measuer the hood bump stops or the radiator cover height adjustment screws, but got lucky when I winged it and slapped it back together. Should have referenced this one but lost track with all the velossatech install write ups recently lol As far as the fitment, I wasn't pleased initially as it wasn't reaching the headlight assembly and had a big gap between the ram air and headlight, but I tinkered with it and got it pushed down and towards the light where it mated up to the headlight housing and the rubber pice near the stock intake opening kind of behind the headlight housing. I didnt tuck it under the rubber like you, the velossatech went over the rubber. Seems like arpad might have done the same judging from his picture. I didn't have any of the rubber screw cover plugs that you mentioned, mine didn't come with any.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. Last edited by RobbyBeefcake87; 04-26-2020 at 01:19 AM. |
04-26-2020, 09:04 AM | #19 |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
I installed mine yesterday, and decided to do the front bumper removal, as I also wanted to clean out the leaves, bugs, rocks etc....I even found a piece of rubber marble in there, must have been from the track runs.
Anyway, I watched a few videos on YT, which showed which screws to remove...I ended up removing 8 screws holding the fender liner as oppose to only three. My arms could not get in there with only three screws removed and I didn't want to kink the liner. Overall the front bumper removal was pretty easy, you just need to deal with a lot of screws nothing very difficult. I think the most difficult part was disconnecting the light harness on the driver's side. The entire time from QJ set up to washing up was about 4.0 hrs being I had to remove the bumper twice...damn light harness! The Big Mouth went on very easily and I was able to get it up against the light housing nice and snug. Fitment is good and solid, with the access I had, I was able to tighten it down pretty tight without cracking the product. And with the locking nuts used, I don't think it will be backing out. Tip: Use the paper towel trick for the sockets to reach the top screws when reassembling, and have a universal knuckle extension on hand. I used 1/4" drive for easier access. And don't forget to connect the light harness on the driver's side during reassembling! Who said getting old was fun! For the test drive, did not notice anything, not even sound, then again my exhaust is loud...LOL! Which was expected however, those leaves that were stuck in my grill will not bother me now when I wash my car!
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
04-26-2020, 10:03 AM | #20 | |
Did you remove your splitter as well or just took it all off in one piece?
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
04-26-2020, 01:31 PM | #21 |
Drives: Black 1SS Join Date: Dec 2018
Can’t wait to install mine, just got it thru the mail, I will be pairing it with a Rotofab Dry, and all Pray Ported stock stuff, I’m curious if anyone thinks I’ll need a retune for these mods ?
04-26-2020, 08:34 PM | #22 | |
Drives: 2018 Camaro SS Join Date: May 2019
From what I understand no tune needed but when you do tune it the adds you have will really help the numbers. The ported intake added to the ported TB give mine the biggest noticable power jump yet. I'm hoping the Velosso can help even a little till the tune. Again...keep me posted. |
04-26-2020, 08:56 PM | #23 |
Drives: like an old lady Join Date: Jun 2012
most likely will need a tune. the pray ported stock tb & intake manifold gave me a p1400 after a couple hundred miles. i ended up not using the tb bc it only made .2 hp more on the dyno. the tuner was able to make the accelerator respond how i wanted without the ported tb.
04-26-2020, 10:40 PM | #24 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2018
Should be fine. I am currently Ram air, ported TB/IM and I am having no issues with codes. I have a rotofab on the way so Ill keep you updated. I will bet getting 2" headers soon so I will have to tune it shortly.
04-29-2020, 07:01 PM | #25 | |
I think what made it easier was removing the additional screws on the fender liner. Another mistake I made was having the car face the sunlight. It made it difficult to see the screws inside the bumper cover to remove. My headlamp (around my head like miners light) helped, but it was still difficult with the sun shinning at me...have your back at the sun would have been the wise thing to do. Again, not difficult, just a lot of screws. If I had to do it again, I'd do it the same way.
04-30-2020, 02:20 PM | #26 |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
So far I see no one excited and enthusiastic about the performance. I'll pass.
04-30-2020, 05:32 PM | #27 |
SNSTRSS
How long did you guys have to wait before receiving the item after ordering it?
2016 Black Camaro 2SS A8 NP
04-30-2020, 07:42 PM | #28 |
I recall a little over two weeks. Booher ordered his within a day of me so maybe he will chime in too.
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“ Last edited by Trochoidal; 04-30-2020 at 08:05 PM. Reason: Typo |
