10-07-2019, 10:48 PM | #1 |
Drives: 2017 Chevy Camaro 1SS Join Date: Oct 2019
Short Squeak noise
Hey y’all,
First time here and I would like to say how proud I am to be a Camaro owner. Now for the lowdown, I recently bought an SS after upgrading from the 1LT. I’ve noticed an odd sound coming from either the engine bay or the exhaust. I was able to capture the sound immediately after shutting off the engine, but this sound tends to happen when I press on the throttle as well. https://youtu.be/sblVMZwcPVk https://youtu.be/24AFYPXP8vo https://youtu.be/zbE8YqZfSxw Again the noise from these videos occur upon pressing on the throttle. Whether I press on the throttle from stop (stop sign or stop light), or letting off the throttle and then a couple of seconds later hitting it again while cruising. As of last Saturday, I’ve gone to the dealer and they were able to somewhat replicate the problem (of course it doesn’t want to make any noise when I’m at the dealership) one of the GM Engineers mentioned it could have been an exhaust valve. So he lifted the car and noticed the exhaust was loose and tightened it up, as well as gave me new headers (car is still under warranty so I wasn’t charged for it). After I took it back, the squeak came back again. Noise occurs in any of weather and road conditions. My newbie guess seems to be occurring either in the exhaust valve or the serpentine belt. After scouring for hours, I noticed this Beamer user had somewhat the same “short squeak” issue EXCEPT his seems occur when the engine turns on, the opposite of my problem. https://youtu.be/s5BPB1G9ME4 Which begs the question: WHAT THE HECK COULD THIS POSSIBLY BE? Last edited by AutoPenalti; 10-07-2019 at 10:59 PM. |
10-08-2019, 07:55 AM | #2 |
Drives: 2019 2SS Riverside Blue Metallic Join Date: Sep 2018
As someone whose extremely familiar with the exhaust squeak issue, I have one question, and one thing for you to try.
When you put the car in accessory mode (hold the ignition with foot off the break), and go into the sound management settings (assuming you have the NPP option), and you switch between track and stealth, does it squeak? If it doesn't, then it may be the AFM valves or could potentialy be the throttle body.
Order # WKXN0F 2SS Riverside Blue Metallic, A10, NPP, 56V
Ordered 9/15/18 1100......9/17/18 3000......9/19/18 TPW: 11/26/18 3300......11/9/18 TPW: 11/26/18 3400......11/12/18 TPW: 11/26/18 4300......11/22/18 BUILT! VIN: 1G1FH1R72K0123562 4B00......11/27/18 Waiting for Dispatch! Tentative delivery date of 12/11! 4300......11/28/18 Waiting for the train to Florida! 4200......12/5/18 SHIPPED! 4800......12/14/18 5000/6000......12/18/18 SHE'S HOME BOYS! Follow me on Instagram! @the_3ngin33r |
10-08-2019, 08:05 AM | #3 | |
I'd also like to point out that the squeak doesn't seem to occur until after about ~10-20 minutes of driving, after the engine is warmed up. |
10-08-2019, 08:39 AM | #4 | |
If it is, you still have AFM valves, so it could likely be one of the AFM valves.
10-08-2019, 10:59 AM | #5 |
Yes it is an Automatic. What I find annoying is that this seems to occur frequently, even on my way to the dealership for them to check it out. When I tell them what the issue is, I tell them that the way to replicate the noise is to drive around for a bit and listen to the squeak. The GM engineer literally took the car for a test drive for about 15 minutes and told me he couldn’t hear the noise. As soon as he said that, he pressed on the gas and break at the same time and you could hear it immediately. It was very faint but it was enough for him verify what I was talking about. He tried it again and of course, the noise could not be replicated. I told him to shut off the engine to hear it and of course, the noise didn’t appear. I would have thought it would have even sounded louder considering where he and I were at it was a pretty “echo-y” place. His theory seemed to be it was an exhaust issue, he noticed that the exhaust was a bit loose and tighten it up. He also was nice enough to give me new headers. I will ask them to check the AFM valves. Again I've been only to capture the noise once the engine shuts off (only because I can hear it more pronounced in a quiet area rather than a busy street) This car is still under warranty until May 2020. I'm at 29940 miles. So I guess I got that going for me at least.
10-08-2019, 04:43 PM | #6 |
So I was able to finally replicate it while driving, as stated the noise can be produced when engaging the throttle as well.
https://youtu.be/lCwb_vpDcXI Here’s another one with a quieter surrounding. Notice the pronounced squeak upon accelerating. https://youtu.be/WUdLXSlss9w |
10-08-2019, 05:45 PM | #7 | |
You should try figuring out if your car makes the noise on the V4 to V8 switch when accelerating or if it makes it when going from V8 to V4 while cruising. There is a dash view that shows you what mode you are in while driving. It really sounds to me like it's the AFM valves. So if it squeaks when you do what I said above, and it squeaks, it's the AFM valves
10-08-2019, 06:47 PM | #8 | |
Upon further researching with the AFM valves, this guy has the issue I’ve been hearing while driving. Except his seems to be on certain modes, I have the same issue as he does when he has it on “sport” mode. Mine seems to occur on any mode, I want to try and see if changing it manual would disable the noise. https://youtu.be/t0dysI0tHZU I wonder if the engine noise shut off is all apart of that. It’s almost the same, if not, exact noise. Last edited by AutoPenalti; 10-08-2019 at 06:59 PM. |
10-08-2019, 07:00 PM | #9 | |
Ordered 9/15/18 1100......9/17/18 3000......9/19/18 TPW: 11/26/18 3300......11/9/18 TPW: 11/26/18 3400......11/12/18 TPW: 11/26/18 4300......11/22/18 BUILT! VIN: 1G1FH1R72K0123562 4B00......11/27/18 Waiting for Dispatch! Tentative delivery date of 12/11! 4300......11/28/18 Waiting for the train to Florida! 4200......12/5/18 SHIPPED! 4800......12/14/18 5000/6000......12/18/18 SHE'S HOME BOYS! Follow me on Instagram! @the_3ngin33r Last edited by Lithias; 10-08-2019 at 08:29 PM. |
10-08-2019, 08:19 PM | #10 |
Drives: 2016 Nightfall Metallic Grey 2ss Join Date: Oct 2017
#PIC6289A
Some customers may comment on a Check Engine Light (CEL) or an exhaust noise. Upon further inspection, dealership technicians may find a P12FD or a P12F0 set. Cause This concern may be caused by an exhaust actuator that was installed but the learn procedure was not completed. This concern will occur on new vehicles with low mileage, or on vehicles that recently had service work done to the exhaust system. Then give them this bulletin number also: #16-NA-003 Some customers may comment on hearing a squeak or chirp noise coming from the rear of the vehicle. The noise may be reported as being intermittent. Cause The noise may be caused by the opening/closing of the exhaust values during normal performance. Additional Option RPOs Chevrolet – Equipped with LT4 Engine, LGX Engine / NPP Exhaust, LT1 Engine / N10 Exhaust or LT1 Engine / NPP Exhaust Cadillac – Equipped with LF4 or LT4 Engine Confirm that the front or rear/tail pipe valves are the cause of the condition by activating the flow control function of the exhaust system. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in SI. Use GDS to verify the exhaust flow control valves open and close when commanding the Exhaust Flow Control Valve On and Off, with a scan tool. For Camaro and Corvette models, the engine sound management setting must be set to “Auto” to enable the scan tool to operate the valves. Note: The noise may only occur during valve opening OR closing of a valve, not always both. Command the flow control functioning numerous times and listen for any squeak/chirp noise, over and above the normal activation noise. If the squeak/chirp noise is evident, continue ahead to the lubrication service procedure below. |
10-08-2019, 09:05 PM | #11 |
Ugh, lubricant? I’ve searched all over that it barely lasts less than a couple days before the sound returns. I’d rather them just replace the whole exhaust together since I’m under warranty. I’ll keep you guys updated when I go in again on Saturday.
Thanks for this guys, ya’ll have been amazing! Any others lurking are welcome to chime in for other users who have this problem, helps out a lot! |
10-09-2019, 07:48 AM | #12 |
Narrowing down the noise, I've come across that putting the car on manual mode disables the sound. I check the service bulletin for #16-NA-003 but that seems to apply only for 2016's. Will the dealership still accept the bulletin for a 2017? Does it matter?
10-09-2019, 08:57 AM | #13 |
Old school tech
Drives: Ruby 1LE - 2024 2SS 1LE Join Date: Mar 2014
Could be a belt tensioner or pulley. I found a squeaky tensioner one time that made that noise, with the same stepping on the throttle/shutting the engine down situation.
Previous Camaros: 2021 Riverside Blue 2SS/RS A10 | 2019 Riverside Blue 2SS/RS M6 | 2013 Crystal Red 1SS/RS A6 | 2010 Imperial Blue 2SS/RS A6
One & only Corvette: 2015 Stingray Z51 Ordered 2024 Radiant Red 2SS 1LE Ordered: 6/15/23 Accepted: 7/5/23 3000 - 7/5 ---> 3100 - 7/19 3300 - 7/20 --> 3400 - 7/20 -->TPW - 8/7 4300 - 8/14 --->4B00 - 9/5 DELIVERED 9/20!! |
10-09-2019, 09:45 AM | #14 |
That was my initial guess since I tend to hear a faint squeal (not squeak) during cold start, but for a pulley or tensioner to fail at 29k miles seems odd.
