08-12-2018, 03:27 AM | #1 |
Drives: 2017 ZL1 and 2018 SS 1LE Join Date: Oct 2015
Big problem please help
After having my engine replaced with a LME 416 Stroker, the car was perfectly fine. We base tuned it for a light break in before final tuning it. Anyways, after the final dyno tune, I went to do the first pull and upon shifting, the car would not grab gear at all. This only happens at high rpm, it grabs gear and drives just fine normally but wot it will go into nuetral but will not go into next gear. I am thinking it is a clutch issue, however I am scared that it is a transmission issue now too. I am not blaming anybody, however the car went into the shop with a functioning clutch and trans and now this is happening after they removed and installed everything. Any clues as to what is causing it?
08-12-2018, 07:33 AM | #2 |
Drives: 2017 2lt rs Join Date: May 2017
Sounds like clutch is slipping
08-12-2018, 08:25 AM | #3 |
Drives: 2018 Camaro 1SS/1LE Join Date: Feb 2015
You have a brand new 18 and you replaced the motor?
08-12-2018, 09:32 AM | #4 |
Drives: 2017 50th Camaro SS Join Date: Jul 2016
Yea, it's called modding. Guy wanted some cubic inches.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
08-12-2018, 09:42 AM | #5 |
08-12-2018, 09:50 AM | #6 |
Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
The guy is here to get answers to his question regarding his shifting issue, not to be flamed because he pulled his engine from his car...
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
08-12-2018, 09:52 AM | #7 | |
Drives: SS Vert Join Date: Dec 2013
Exactly. You can't do something like this and not expect to have issues. I just don't get it.
I want to go to college for the rest of my life.
08-12-2018, 09:55 AM | #8 | |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Can you not shift in and/or out of gear? Or, is it in gear and the car does not accelerate (RPMs go up and speed does not). Sounds like the later. I really don’t think it’s the trans. Sounds like clutch. |
08-12-2018, 10:01 AM | #9 |
Some of you guys are not helpful at all. His first motor was modified with FBO and cam which means no factory warranty. He had a failure (piston to valve contact). He decided to go big with a new built stroker motor from LME instead of repairing his LT1. So now the history lesson is over.
OP - I don't have much advice for you but to state the obvious that I see little choice but to go back to the shop that did the engine swap and have them trouble shoot the issue. Good luck for it to be an easy fix - I know you could use some good luck with the journey you've had so far.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) Last edited by SSDan; 08-12-2018 at 10:47 AM. |
08-12-2018, 12:52 PM | #10 |
08-12-2018, 12:54 PM | #11 |
Car will accelerate fine in whatever gear it is in, but if I want to shift into the next gear and put the clutch down, it will go to nuetral but when I try to get next gear it will just grind. I have to wait for the rpm to drop to get next gear
08-12-2018, 12:55 PM | #12 |
08-12-2018, 01:15 PM | #13 |
Thank you Al Oppenheiser!
The shop screwed up the clutch install.
08-12-2018, 03:24 PM | #14 |
Drives: 2018 Camaro RS V6 Convertible Join Date: Jun 2018
This may be useless or helpful, but in my last Mustang I had a similar issue, and it was common to the car. The issue was with the power and trying to rip off a quick shift everything torques over a bit which affects the linkage, made it difficult to get 3rd gear, often grinding.
Maybe something to look at? And ignore the people that don’t get hot rodding |
