07-06-2021, 08:34 PM | #15 |
Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
My ss 1le was 3600 even on a Cat scale ÷-20lbs gaurantee.. rear seat delete, 19in apex wheels..
2017 1LE Hyper Blue
07-06-2021, 11:08 PM | #16 |
Drives: 2018 ZL1 1LE Join Date: May 2020
My 18 M6 ZLE was 3860 with about 7/8 tank of gas without me in it.
09-07-2021, 10:28 AM | #17 | |
Doing my Kooks axle back next week should take it down near 3700
'20 ZL1 1LE A10,
09-23-2021, 06:37 PM | #18 |
Continuing this topic, my OEM ZL1 quad suitcase weighs 42# and my Kooks AB quad with a very small muffler weighs 20#, my car weighs 3728 with 2 gal.
'20 ZL1 1LE A10,
09-24-2021, 11:31 AM | #19 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Sorry, no stock ZLE weighs only 3742lbs. As others have noted, a regular 1SS 1LE weighs a little more than that with no blower and the associated extra equipment. Also, no scale that has a near 200lb readout variance depending on having the car "in exactly the right place" should be trusted to give accurate weights at all. The best way to weigh a car is with four individual wheel scales. This is the way every competition series I've ever seen does it, up to and including Formula 1.
The published curb weight for a ZLE coupe with manual trans (the lightest version) is 3883lb, and these are usually optimistic. Camaros seem to come in very close to their published curb weights. Lighter wheels and exhaust could shave a few pounds off this, but not 141lb.
Matt Miller
2020 SS 1LE |
09-24-2021, 11:48 AM | #20 | |
It's not stock and I weighed it on Bandimere Raceway's scales, which is the platform used for all NHRA races. Sorry, I can read and it weighs 3728. Pro Stock cars weigh within +-5 lbs. on this scale.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 09-24-2021 at 12:11 PM. |
09-24-2021, 12:16 PM | #21 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Since you mentioned your car is NOT stock, exactly what was done SPECIFICALLY on your end to make this car ROUGHLY 200 pounds LIGHTER than a stock ZL1??? THAT'S alot of weight reduction.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
09-24-2021, 01:15 PM | #22 | |
Something is clearly way off here, and common sense should tell you that when we know what other Camaros weigh as well as what the manufacturer tells us they weigh. When you were willing to post that your car only weighed 3555lb, that tells us that you aren't using critical thought as a reality check on your findings. Reality checks also tell us your car weighs significantly more than 3742. If something is too good to be true...it isn't true.
Matt Miller
2020 SS 1LE |
09-24-2021, 02:46 PM | #23 |
And when I pull the passenger and rear seats again it'll weigh ~3680. There's lot of guys here with equal or greater Jenny Craig.
'20 ZL1 1LE A10,
09-24-2021, 08:25 PM | #24 | |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
That said, Car and Driver and MT both weighed the A10 ZL1 and got 3,925 and 3,926 lbs, respectively, with a full tank of gas. The ZL1 M6 weighed 3,904 lbs. Motortrend weighed the M6 ZL1 1LE and got 3,837 lbs, while C&D's M6 ZLE weighed 3,842 lbs, both with a full tank of gas. C&D weighed the 2019 ZLE A10 and it was 3,886 lbs, I couldn't find MT's weight for the ZLE A10 (or if they even tested one). So, with only 2 gallons that A10 would have weighed 3,779 lbs, while the M6 versions would have been in the 3,730 lbs range. Compared to the competition (Shelby GT500 and Hellcat variants), the ZL1 and ZLE are "relatively light". Heck, both magazines weighed the regular 2018 Mustang GT which weighed 3,860 lbs (A10) and 3,878 lbs (M6 by C&D), but with 3 less gallons of gas due to its smaller fuel tank. That's heavier than the M6 ZLE, and within a few pounds of the M6 ZL1, esp. if you take away 3 gal from a ZL1.
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
09-24-2021, 10:03 PM | #25 |
Do a search. There's extensive listings of Jenny Craig items and weights. My initial post had a typo.
'20 ZL1 1LE A10,
09-25-2021, 05:58 PM | #26 |
Consider the difference between having a low fuel load and a full gas tank that is used for a curb weight for starters. Using the 3886 lb that Idaho says C&D found for a 2019 ZLE A10, then subtracting 105 lbs for the fuel difference (OP specified 2 gal) gives 3781 lb. Then subtracting another 40 lbs for the AntiGravity battery listed in the OP's sig gives 3741 lbs. Hmm, this 3742 lbs report is not sounding so crazy.
09-30-2021, 08:30 AM | #27 |
Robert Weathers has done a lot of weight loss mods to his 2017 1LE and has gotten car down to around 3414lbs. CF doors, hood, front fenders, seats, BMR suspension components throughout, DSC MRC coilovers with DSC controller(almost done with testing and out on market for purchase) So much weight lost that he had to add ballast weight to run in USCA autox events. Has to be 95% published corn weight. This car FLIES on road course at 3414lbs. You can bet there aren’t many cars out there in similar size that can beat this car on a road course or autox. Look him up. He also publishes Mad Motor Magazine.
'20 ZL1 1LE A10,
09-30-2021, 08:50 AM | #28 | |
Matt Miller
2020 SS 1LE |
