09-03-2020, 12:46 PM | #1 |
Drives: Camaro ZL1 Join Date: May 2020
Drag Strip after car upgrades
Recently got Texas speed headers and flex fuel kit installed (was running at 68% ethanol). Car already had upper pully and cold air intake. Just took it out to the strip yesterday after upgrades. Running on the stock goodyears. Traction sucked. Was using launch control at 2,800 RPM with 8% slip. Outside temps were around low 90s. 6 speed manual btw. My time has improved to very low 8s and high 7s for the 1/8th Mile. Before the upgrades I was running mid to low 8s. Never hit into the 7s. Please note this is my 3rd time in my life at the drag strip so I am not experienced in anyway. Looking at the slips my 60 time has improved from last time avg about 2.1 now. Have yet to make it under 2. However my speed went down from like 95 to 90 mph at the finish, even though I am getting faster times. Just wanted to share my numbers and get some thoughts. Will post slip in next post.
09-03-2020, 12:48 PM | #2 | |
https://youtu.be/ydqID1H_dSg
Link is vs the hellcat. This guy usually runs mid 7s with drag radials but did not put them on at the time. Slip is for this race |
09-03-2020, 01:49 PM | #3 |
Drives: 2020 ZL1 1LE Shock 1968 Pontiac GTO Join Date: Apr 2020
Nice to see some improvement for the upgrades, do you have slicks on the car? They would help tremendously. The big thing your fighting is the 6speed, very hard to get them to hook with the amount of power you have
Ant |
09-03-2020, 02:15 PM | #4 |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
Are you using the NLS feature on your car? I have even less experience than you, but it seemed there was quite a pause during the shift? And your launch, I think it was pretty good.
09-03-2020, 03:56 PM | #5 |
Drives: 2019 Camaro ZL1 M6 Join Date: Nov 2018
This time is pretty close to what stock automatic LT1's are running.
93 mph in the 1/8th seems a bit low no? I think with better tires and more seat time you will improve a lot, but I would really have hoped the MPH was higher here. Last edited by gaveup; 09-03-2020 at 04:15 PM. |
09-03-2020, 04:21 PM | #6 | ||
Better tires will do miracles, I am told. I thought it would be higher as well. Not sure what is happening. I shift right before redline. Not perfect by any means but I dont miss the shift by a lot. Car was just tuned last week as well. Before the upgrades I was running about 95 to 96 avg from what I recall. |
09-03-2020, 06:09 PM | #7 |
Craig
Drives: 2019 ZL1 1LE Join Date: Jan 2019
NLS is not the rev-match. NLS allows you to stay on the gas and just stab the clutch and grab next gear, throttle has to be 100% to the floor and people advise being above 5500rpm.
09-03-2020, 06:29 PM | #8 | |||
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Get some better tires that don't take so long to warm up. That 60 foot needs work but that's from the bad traction. I'd also say to not use the launch control feature. I believe it's been proven that not using it has better results. |
09-03-2020, 06:57 PM | #9 |
09-03-2020, 07:12 PM | #10 |
Two Lane Blacktop
Drives: '18 Camaro 2SS Join Date: Jul 2019
Yes you are spinning a ton, and coming out high RPM on tires is causing some of that
09-07-2020, 11:50 AM | #11 |
Drives: 2019 ZL1 A10 Join Date: Aug 2018
So does the OP use the No Lift Shift? If not, he could try and compare times.
09-07-2020, 10:23 PM | #12 |
Drives: A10 ZL1 Join Date: Mar 2018
Would U all suggest launching from idle? I’m around 824 RWHP and getting too much spin from about a 2,000 launch
09-08-2020, 08:25 AM | #13 |
09-08-2020, 08:38 AM | #14 |
You leave the accelerator pedal to the floor and never lift when shifting...hence the term "No lift shift".
2016 NFG 1SS A8
