05-26-2023, 10:57 AM | #1 |
Drives: SS Camaro Join Date: May 2023
Help!
Hi all, I have a 2010 ss camaro and as soon as I turn on the AC, both cooling fans under the hood come on full blast until I turn the car off (extremely loud). It happens no matter what the outside temp is The temp sensor has been replaced and the gauge is always normal. I've tested the fan relays and they're fine. No error codes come up with a scan either. Does anyone know what could cause this? Any help would be greatly appreciated!
05-28-2023, 04:21 PM | #2 |
You might want to post your issue in this section, you might get some help easier. Because there is no more Camaro team I have read. GL
https://www.camaro5.com/forums/forumdisplay.php?f=70
06-02-2023, 06:10 PM | #3 |
Thank you
06-30-2023, 11:55 AM | #4 |
It was the pressure switch, thanks for all the help!
06-30-2023, 04:59 PM | #5 |
Glad you got it fixed!!
