04-28-2021, 09:47 AM | #1 |
Drives: 2018 ZL1 Hyper Blue A10 Join Date: Jan 2018
Input: Cam or Not to Cam
I'm in the process of finalizing my build and the only thing I'm not sure of is a cam. I know this decision will definitely effect my end Hp, Trying to figure out if a cam package is worth the extra dollars and do I need that much power.
Has anyone regretted camming their car. I guess this would mainly be for those that the car is mainly for street use. Mine is not a daily driver, my only real issue is do I want to go into the motor or just go full bolt on. When I say bolt on I meaning Maggie 2650, headers, cai, etc..... Not that it matters but out of curiosity how often will I be pulling up to the gas station?? Lol |
04-28-2021, 09:54 AM | #2 |
Previously CS10SS
Drives: 2017 ZL1 A10 Join Date: Jan 2017
Yes, I would 100% recommend a mild cam and while you're inside the engine... swap out the oil pump. After my car was done I actually wished I had gone with a little more aggressive cam but she is fantastic & drives like stock, until you get into her.
My build thread - https://www.camaro6.com/forums/showthread.php?t=589244
'02 Trans AM - sold
'05 SRT4 - sold '05 STI - sold '96 300ZX - sold '10 2SS/RS M6 455rwhp - sold '13 ZL1 M6 720rwhp - sold '17 ZL1 A10 930rwhp - Katech Built |
04-28-2021, 10:15 AM | #3 |
Yeah, I thought about changing the oil pump if I go that route...…
Need to see if katech ever came out with one for the Gen6... |
04-28-2021, 10:52 AM | #4 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
If you should decide to install a cam, you can choose a cam with a smooth idle but still has a 32% fuel lobe for more fuel. |
04-28-2021, 11:02 AM | #5 | |
'20 ZL1 1LE A10,
04-28-2021, 11:05 AM | #6 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
When you say you drive daily 20-30 mile cruises you mean you commute to work with it right? I assume yes, but "cruises" sounds more like recreational driving than a commute.
04-28-2021, 11:08 AM | #7 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
A cam would help, because you can choose a higher fuel lobe for the high pressure pump. There are some good options for smooth idle/mild cams available as well. This would also eliminate the DOD lifters that occasionally fail. Jannetty smooth idle Katech K3 Cammotion PD 220/236 -118 or 119, 120 Lingenfelter GT31 or GT35 And yes definitely install the Katech wet sump oil pump at the same time!
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 |
04-28-2021, 11:19 AM | #8 |
Drives: 2019 ZL1 Join Date: Mar 2019
+1 for cam, also add headwork to that. As it will add more power and lower your boost levels at the same time.
My cam is middle of the road, slight buck @ idle. Past 1k rpm's drives no different then stock, except for the power.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
04-28-2021, 11:20 AM | #9 | |
Previously CS10SS
Z OH 6 makes a very good point about being realistic (and honest) with yourself on what you are planning on using the car for.
'02 Trans AM - sold
04-28-2021, 11:21 AM | #10 |
How much boost are you seeing with your setup?
2018 Camaro ZL1 A10
04-28-2021, 11:22 AM | #11 |
Just recreational. Semi-retired.
'20 ZL1 1LE A10,
04-28-2021, 11:25 AM | #12 | |
It will see only the occasional trip to the drag strip and no road course, so it will be mainly a street car. So would be putting the cam in be too much power?????? I know I can always add it at anytime. I'm just the type that likes to do everything I want in one move. I'm also at sea level so that should make a difference to a degree.... Last edited by Grumpy1; 04-28-2021 at 11:26 AM. Reason: I'm also at sea level so that should make a difference to a degree. |
04-28-2021, 11:28 AM | #13 |
Right about 15psi.
04-28-2021, 12:09 PM | #14 | |
All this comes down to, don't let your ego get the best of you. Bragging rights is cool for a bit but doesn't matter much anymore when you've already told everyone what you have and then you can't really get the power down to enjoy it. You'll likely end up regretting going too far for your intended purpose. I really can't stress this enough, be honest with yourself about what you want to do with the car and just build accordingly. 700whp is a LOT in these cars and will give you smiles every time you drive it. |
