Old 04-25-2021, 12:30 PM   #1
20Bluezl1
SC3R track temp pressure/ temps
So im going to do my first track day with SC3R tires.my question is do I go by the zl1 1le gm specs? Which are cold 26psi and hot 35. I'm assuming during the day I will probably have to take air out snice it will probably pass 35psi.
Old 04-25-2021, 02:44 PM   #2
Badmojo
aka BeastZL1
Badmojo's Avatar
34-36 hot is the sweet spot for me. I usually start 28-29 psi cold and let a couple of psi out after the first session. You don't want to start too low or you'll roll the tires on the first couple laps.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 04-25-2021, 02:55 PM   #3
ZRacerLE
ZRacerLE's Avatar
Drives: The DSSV Twins: ZR2 and ZLE A10
+1
ZRacerLE is offline   Reply With Quote
Old 04-25-2021, 04:25 PM   #4
20Bluezl1
Anyone use a tire pyrometer to keep temps in check and verify pressures are good? I was going to try the chalk trick.
Old 04-25-2021, 09:00 PM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
You have to give the 3Rs 2 laps or so before leaning on them otherwise you will kill them quickly. Start at 26-28 depending upon your taste and aim for 34-35 hot. Anything above 35 is a bit greasy for me. These tires require a bit of restraint before using them appropriately. I know someone who corded a set in (2) 25 min morning sessions leaning on them immediately.
Old 04-25-2021, 09:41 PM   #6
20Bluezl1
Sounds like cold 28 is the magic number to start off, and 35 is the happy medium to shoot for.
Anyone know what range of temperature goodyear recommends the tire should be at? Trying to see if I can fine tune my psi with pyrometer to maximize the tire patch and life.
Old 05-05-2021, 08:30 AM   #7
Badmojo
aka BeastZL1
Badmojo's Avatar
FYI, for NASA Time Trials I increased the starting pressure to be ideal for the 2nd flying lap. This meant going out at 30 psi front/rear for the first session and then dropping it to 29 psi for the subsequent sessions. It seemed to work, but my hot pressures were too high after the 4th lap and they rose to 38ish on the cooldown lap.
2019 Camaro ZL1 1LE
Old 05-05-2021, 08:51 AM   #8
G61LE
G61LE's Avatar
Drives: 2019 Camaro ZL1 // 1LE
34 - 36 is the sweet spot. I normally start off at 26, and on two separate events, the tires never got over 30 - 31 ish, and corded the left front tire. Both of these weekends the outside temps never got over 60ish and the track stayed pretty much cold. I had hoped some spirited driving would heat up the tires but they didnt. So my advice is pay attention to outside temps when adjusting cold tire pressures.
G61LE is offline   Reply With Quote
Old 05-05-2021, 09:45 AM   #9
Zl1+911
Drives: 997 GTS, ZL1 A10, ZLEM6, ZLEA10
i have found that 1) starting at anything below 29 increases wear dramatically during the warm up time (which is not short) - hence i start around 30 and then bleed off, even though in the forst session they get up to 38/39 towards the end 2) do NOT push the car till your tires are "warm" per the in dash menu - the outcome of that will not be good.
Zl1+911 is offline   Reply With Quote
Old 05-05-2021, 12:35 PM   #10
Badmojo
aka BeastZL1
Badmojo's Avatar
I find that the dash board tire temp gauge lags the actual temp by about 1 lap.
2019 Camaro ZL1 1LE
