Old 05-08-2021, 04:05 PM   #15
Yosh6
Yosh6's Avatar
Drives: 2024 Toyota Camry XSE
I've had them move just like Josh's. I called Mickey Thompson and they said use Permatex Hightack Cement. I did that on my Camaro and I also did it on my C7. Tire will not move on wheel. The way we did it is dry mount and then balance. Mark the valve stem/tire and then break them back down. Apply a light coat of Permatex (comes with brush) on the tire and bead of wheel. Wait till its tacky and the air them back up. No spinny on wheel anymore. I was told the same thing by Mike at Kentshotrodgarage where I bought the Race Stars and Drag Radials/skinnies. Here is a link to what I used.
https://www.bing.com/aclk?ld=e81al8J...d5e29189&ntb=1
This looks like a much better solution. From my Original Post: " According to Mickey, RTV gives it a "double whammy"; provides lubrication for seating bead and will help hold the tire from slipping on the rim after it bonds. (Clean-up? They say comes off easily with mineral spirits).
They must have misunderstood my question about clean up. I'm sure mineral spirits would clean it off easily WHEN IT IS WET. I meant dry. Cleaning the dry RTV off the wheels was a bear, a big bear. 45 minutes for each wheel, easy. Solvents didn't touch it. Ended up using wire brushes and lots of elbow grease. Never shall I do that again!
2016 1SS - Bought: 8/2017 Sold: 12/2023
Yosh6 is offline   Reply With Quote
Old 05-08-2021, 04:19 PM   #16
6spdhyperblue
Drives: 6th gen
Nice. A few questions. How’s the wiggle/sway on the throttle over 100? What psi? How tall actual?
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
Old 05-08-2021, 09:34 PM   #17
Yosh6
Yosh6's Avatar
No wiggle or sway. Psi -17 in pits aiming for 18 after burnout (with nitrogen; initial psi may need to be 16 or 16.5 with air - you'll have to experiment). Back in pits after first pass, psi was 18. Tire temperature - 90 before first pass, 96 back in pits. Measured 27.5” from top of tire to ground on the car at 18 psi.
Old 05-10-2021, 10:30 PM   #18
BDPhoto519
BDPhoto519's Avatar
I just picked up a set of the DBR's for this season since the ET R's are non existent.
I haven't tried them yet, but I keep hearing good things, thanks for your input!
2018 Camaro 2SS A8 Redline Edition
BDPhoto519 is offline   Reply With Quote
