04-03-2021, 02:18 PM | #15 |
I don’t know how much power you need to get the 275 to slip but I can’t get them to not grip
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) Last edited by 6spdhyperblue; 04-06-2021 at 09:34 AM. |
04-03-2021, 08:14 PM | #16 |
Drives: 2016 Camaro SS Join Date: Jul 2020
04-03-2021, 08:39 PM | #17 | |
Supercharger mixed with sticky tires equal questionable stock SS driveshaft lifespan...
04-04-2021, 06:35 PM | #18 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
26 inch is going to give a gear ratio advantage. I am going from a 27.7 to a 27.0 tire and gear ratio goes from 2.77 to a 2.83. Going to a 26 inch tall tire you will be closer to a 3.0 rear gear ratio . Make sure you add some width picking out the size you want . Let the wider tire make up for the bigger diameter and have a equal foot print.
04-04-2021, 06:37 PM | #19 |
04-06-2021, 09:19 AM | #20 |
I ordered a set of et street r bias ply in a 28” to see if I can trade some mph for et. I’ll do a write up. I love the 275/40 et street r radials but wanted to experiment. Car will be the same besides weather
04-06-2021, 10:47 AM | #21 |
Wouldnt the taller tire do just the opposite? shorter tire better ET, less MPH , just my thoughts no actual proof LOL
04-06-2021, 11:04 AM | #22 |
I was thinking radial to bias ply would do that, maybe the height will offset it some. There was no height choice. We shall see.
04-06-2021, 06:10 PM | #23 |
Drives: like an old lady Join Date: Jun 2012
the taller tire tire will cost et and mph both on a car that isn't spinning much to start with. there is a weight savings in bias ply but it will be more than offset by the height difference.
i hope you got some bias fronts to go with those rears.
04-06-2021, 06:33 PM | #24 |
My 275 et street r still have plenty of meat on them maybe I’ll cancel this order
I think these bias plys are heavier too. I just wanted to see what they would do real world. I couldn’t get the radials to spin ever on the strip
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) Last edited by 6spdhyperblue; 04-06-2021 at 07:43 PM. |
04-06-2021, 08:09 PM | #25 | |
04-06-2021, 08:41 PM | #26 |
Drives: 2020 LT1 Join Date: Dec 2019
I too was curious about the difference. I'm M6 and could only get 1.7 60 with a 26" DR2. Could not get a consistant launch. I've mounted 28" bias plys that I will try out within the next week or two. I'm lazy, and want to find a consistant RPM range to where i can dump the clutch and move out. Will a couple tenths improvement on the 60 be negated by the height penalty?
04-07-2021, 01:05 AM | #27 | |
07-13-2021, 07:06 AM | #28 |
I recently tried 28x10.5 Pheonix bias on 17x8s. They would dead hook side stepping at over 6k, and then bog real bad. Im no expert, but im guessing 517/450 isnt enough to necessitate the 28. I'll be going 15" with a 26 next time to maintain sidewall and hopefully be able to roll out without falling on its face.
