03-12-2021, 02:49 PM | #1 |
Drives: Orange Crush 2021 ZL1 1LE Join Date: Mar 2011
Suspension weak spots, OEM Pads?
I'm switching from the Corvette Z06 world for the last 10 years
Just got a 2021 ZL1 1LE and I'm looking it over while I'm breaking it in. Has anyone had any problems with any of the suspension components. I know it's built for the track already, but looking at the rear trailing arms they look like they're flimsy. Also is everyone setting up there alignments per the Camaro High performance manual for the track? OEM brake pads, are they track worthy. New guy appreciates any guidance |
03-12-2021, 03:28 PM | #2 | |
Drives: 2016 Camaro 2SS Join Date: Sep 2009
03-12-2021, 05:09 PM | #3 |
Drives: 2019 ZL1 1LE Join Date: Sep 2010
I don't know of anyone who has broken rear trailing arms. Certainly not something that's going to happen with a stock car. OEM pads are OK depending on the track. The stock brake fluid is not, and should be replaced with a high temp dot 4.
Pretty much do what it says in the track prep guide, and the car will be fine. |
03-12-2021, 05:58 PM | #4 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
If you want to replace any suspension components look into SPL they make amazing products. Couple of guys including myself have switched over to SPL.
03-12-2021, 10:41 PM | #5 | |
Long hauler
SPL looks very nice but that price kills me lol. I got a BMR lower arm and Meganracing toe arm, for my case of daily driving I feel like the metal/metal would get to me
03-13-2021, 10:22 AM | #6 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
The stock parts are plenty strong enough. They only have to react loads in tension and compression. Their stiffness in bending doesn't matter at all, and you want them to be flimsy in torsion since they use axial bearings but need degrees of freedom in other axes as well. If they were uber-stiff in torsion they would add undesirable bind.
There are good reasons for some people to switch to aftermarket suspension links, but strength isn't one of them. I mean, nobody really thinks GM would release a car with suspension links that are too weak to hold up to severe use, right? Mainly you'd do it to remove the impreciseness of the factory rubber axial bushings and replace them with spherical bearings, and to get a stronger type of adjustment than the factory eccentrics and a wider range of adjustment.
Matt Miller
2020 SS 1LE |
03-15-2021, 03:47 PM | #7 | |
Drives: HBM ZLE Join Date: Aug 2017
Also front castor was 6.4 on the left and 7.4 on the right stock. Added the front tension rods specifically to address this. Other than those two things, stock suspension does very well |
05-01-2021, 05:13 PM | #8 |
Drives: '11 SGM 1LT/RS, '02 SOM Firehawk Join Date: Jan 2014
I obviously disagree.
I drove to work on Tuesday, drove home on Thursday and the car was fine. I drove the car to work yesterday and I was getting a violent right-left-right shift in the rear end under hard acceleration and going over bumps. I got it up on jackstands today, and found this on the right rear. That's the lower trailing link. BTW, this is a 2018 2SS 1LE. Never tracked. Never drag raced. Only driven on the road....hard.
Yippee38
05-01-2021, 05:37 PM | #9 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
As for OPs question, there's nothing special that needs to be done to run these cars reliably on the track. Suspension parts and brakes are plenty fine and the recommended track alignment is a pretty solid starting point that you can tweak after driving a bit if needed. All you need to do is flush brakes to a good DOT4 fluid, proper engine oil, and trans/diff fluid changes per the owners manual and high performance supplement. There's also a track setup guide that you can google that will tell you all the different adjustments you can make to fine-tune the handling on the track.
2017 SS 1LE.
05-01-2021, 07:52 PM | #10 | |
Matt Miller
2020 SS 1LE |
05-02-2021, 03:18 AM | #11 | |
I sure as hell hope that's not the case. Who the hell did I piss off enough to do that? Besides, if somebody wanted to mess with my car, there are more drastic ways to do that. That was my first through too though. It looks like it was cut. The fact that part of it is rusted, but part is not, indicates to me that it's been tearing for a while now. It took one good bump, or hard acceleration to tear it the rest of the way.
Yippee38
05-02-2021, 03:22 AM | #12 | |
Yippee38
