Old 08-03-2020, 07:27 AM   #15
GMteSSted
GMteSSted's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by vr46 View Post
Thanks for all the feedback and pics. Curious if any one uses a Kwik Load tilt trailer?(someone mentioned above)
I have a local kwik load dealer measuring the ramp to see if the ZLE will clear the front without the need of ramps. Might go with that one unless someone had negative experience.
I have a Sloan Kwik Load and really like it. For the money it's hard to beat.
I do use 24" long 2x10's to load with. I probably don't need them for the ZLE but I did with the Z/28 and since I have then I use them. It's a very well built trailer, easy to use by yourself. I added E-track the full length and use straps over the tires, never had an issue. The rock guard is great, I wouldn't have an open trailer without one.
The only open trailer I would have instead of the Sloan is a Sundowner Ultra 22. The aluminum, extra length, and storage would be nice to have but at more than twice the price of the Sloan I can't justify the price for only hauling the car 6 - 8 times a year.
Happy towing!
GMteSSted is online now   Reply With Quote
Old 09-04-2020, 04:40 PM   #16
I needed about 4" on the Aluma 18" tilt.
I had a 1" thick 12" square piece of wood that I placed under these race ramps and it worked perfectly.
Old 09-04-2020, 04:56 PM   #17
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
Look at futura love mine, lowers and tows great
https://www.camaro6.com/forums/showt...=559243&page=3
Post 30
Timbo-1LE is offline   Reply With Quote
Old 09-04-2020, 08:45 PM   #18
Post 30
Definitely giving this one some consideration.
The only issue is the 81" width with those high borders. The ZLE is a wider fit and you have to load perfectly straight on this one.
Old 12-23-2020, 08:03 PM   #19
Time for a new Trailer...
Getting serious about a Sundowner 20' with split axles.
Anyone have experience with these?
Old 12-23-2020, 08:50 PM   #20
UrbanKnight
Drives: Fastish
Fender height looks really high
UrbanKnight is offline   Reply With Quote
Old 12-24-2020, 08:02 AM   #21
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
I'll spam post my video but hopefully it has some good info in it.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 12-24-2020, 09:01 AM   #22
They do... but are removable
Old 12-24-2020, 10:45 AM   #23
MoreSpeed
MoreSpeed's Avatar
Attachment 1053709
Still doesn't look like the door will clear the wheels.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG
etc..
MoreSpeed is offline   Reply With Quote
Old 12-24-2020, 10:52 AM   #24
MoreSpeed
MoreSpeed's Avatar
Ps. I sold my car trailer and rent from U-Haul which is surprisingly cheap. I still use my race ramps to prevent scrapping when loading, and I use some wood upfront so the splitter does not hit the lip.
It was not worth the storage hassles and room the trailer took up. That equation works for me, but this approach would not work if you were trailering every weekend.
etc..
Old 12-24-2020, 03:49 PM   #25
GTO_Gregory
GTO_Gregory's Avatar
Drives: 2016 Camaro
Here's a place in Texas called Waco Bill. He's got just about anything you need. Toilets, lifts, aluminum, steel, enclosed, open, etc. I imagine he'll deliver too. www.wacobill.com
I have an eighteen-foot 5K Champion ES Standard. The nice thing about the front air dam is they keep crap off the underside of the towed car - even snow! Get brakes on both axles.
2024 Chevrolet 3500HD Z71, LTZ, 4x4, 6.6 ltr. L5P long-bed.
2016 Camaro 2SS Six-speed, Hotchkis sway bars, Eibach .750" drop springs, Mamo throttle body, E85, BMR stuff.
2006 Quicksilver 6-speed GTO ERL LS3-430, All-Pro 285cc heads, 262/273 .758/.742 116+3 cam, Sheet-metal Intake, 70lb Siemens injectors, SLP, GMM Ripshifter, QA1 Coil-overs front and rear, nylon suspension bushings, Hotchkis, RPM Trans, SPEC twin clutch, SpinTech, Kooks 1 7/8 -2.0", BMR drive train, Kaaz 3.91, Lingenfelter CAI, Baer brakes, mini-tubs, E85.
GTO_Gregory is offline   Reply With Quote
Old 12-25-2020, 07:07 PM   #26
Good point... My Aluma didn't look like it either but Sundowner looks even higher.
Definitely need to make sure though.
Edit: Looks like it works for the Sundowner
Old 12-25-2020, 08:25 PM   #27
Silveradoss573
Drives: Camaro 1LE
Attachment 1053829
Attachment 1053832
Attachment 1053831
Hey again Mike. Hey on the sundowner with split axles, a rep sent me a picture showing the distance from the deck to the top of the tire. Unloaded it's around 10.5 to 11 inches. On Greg's AP4000 trailer (pictures you posted), he told me that his door would not clear even with the fenders removed. He was able to place the car where the edge of the door fell between the 2 tires. Basically he was able to open the door just enough to get in and out. I reached out to another member Derek who has the ultra series non split axle setup for help. He had sundowner raise the deck by a inch or so so his zl1 doors would clear the tires. He still ended up adding another 1/2" after the fact as the 1" still wasn't enough. If I go with a sundowner, I will probably have them raise it by 2" which should be more than enough for my car. Big thanks goes out to both these members for taking time to talk/message me trying to help out.
Silveradoss573 is offline   Reply With Quote
Old 12-25-2020, 08:34 PM   #28
TBZ06
Drives: ZL1 1LE
Thanks to everyone for posting information on the trailers. I did not think about adding spacers under the axles. I just sold my Sundowner because I could not open the doors even after removing the fenders and using race ramps.
I am now looking for a replacement trailer, so all the great post really help with the search. I will have to take a look at the Sundowner with the split axles to see if that would work better. They are great trailers, the build quality is really good, and they pull really well.
Last edited by TBZ06; 12-25-2020 at 08:43 PM. Reason: Adding additional information
TBZ06 is offline   Reply With Quote
