04-09-2020, 01:46 PM | #1 |
Drives: 2014 SS - Sleeved 427/Procharged Join Date: Mar 2017
Crankshaft damage
I've got a weird one. Long story short I took my car to a shop because it still wasn't making the power it should. They tore into it and said the crank snout was damaged because the ATI damper keyway wasn't aligned properly. Can this even happen? I looked at the super damper installation and didn't see anything relating to that. I'm kinda pissed the crank is "trashed". I attached the two photos they sent me
04-09-2020, 03:01 PM | #2 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Looks like it sheared the key off to me. It may not be fully "trashed" after a little clean-up with fine emery cloth. They'd have to check the size of the snout and maybe get a new ATI, and hopefully you still have the proper interference fit. Hard to say just based on these two pics, though. I can't tell what's metal and what's maybe just anti-seize.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
04-09-2020, 03:37 PM | #3 |
RobZL1 would that damage cause the car to make less power? The car isn't making what it should
04-09-2020, 04:14 PM | #4 |
fo'shizZL1
If the balancer was spinning on the crank, then yes. Any idea what the manifold pressure was, and was it reasonable for your mods?
04-09-2020, 04:47 PM | #5 |
I was running about 16psi but it never got to that
04-10-2020, 04:59 PM | #6 |
Drives: it changes Join Date: Nov 2010
No harm...that's ****ed.
That crank needs replaced ( and balancer ) Double key or key/pin whatever goes back in |
04-11-2020, 07:57 AM | #7 |
fo'shizZL1
I'm not yet on the totally f'd train with this one. I'd want to see what it looks like and check the diameter once it's been cleaned up if it were mine.
04-11-2020, 10:31 AM | #8 |
Get some glasses first.
04-11-2020, 09:49 PM | #9 |
fo'shizZL1
So, you wouldn't try to clean it up with some emery cloth, remove the remainder of the key, check the diameter of the snout, and see if it's salvageable prior to pulling the motor? If it was mine, that's what I'd do. If you look under the oil pump, it just looks like the key and the balancer have deposited themselves onto the snout. I'd clean it up, check the diameter, press on a new balancer, and pin it twice.
04-11-2020, 11:55 PM | #10 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
I would guess the crankshaft bolt came loose. Additionally to add what’s already said, use an ARP Crankshaft bolt and torque it to 250 foot lbs. it will stay secured.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
04-12-2020, 04:05 AM | #11 | |
Well it didnt before...keyed, on a good crank, with a good pulley. The pulley is an interference fit onto a clean crank....that crank is ****ed. Now of course he can throw together anything he wants..but dont expect it to last long. |
04-12-2020, 05:46 AM | #12 |
Has to be a press fit pin any looseness will lead to what is shown.
04-12-2020, 07:16 AM | #13 |
fo'shizZL1
Hence my point. If it cleans up and the diameter is still good, press and pin a new balancer and go to town. If the diameter is too small, time for a new crank.
04-18-2020, 01:05 PM | #14 | |
Drives: 2012 ZL1 Camaro Victory Red Join Date: Jan 2013
2.55 UPPER PULLEY,100MM IDLER PULLEY,160 STAT,PORTED TB,PORTED SNOUT,MSD PLUG WIRES,NKG PLUGS,KENNE BELL EXTERNAL FUEL PUMP,2"KOOKS HEADERS,HIGH FLOW CATS,3"CORSA 60LB DEKA INJECTORS TUNED BY FROST 580RWHP,571RWTQ.
