02-27-2020, 07:07 AM | #1 |
Lt4 DOD delete, cam, etc, 20 psi oil pressure
So I recently installed a Lt4 short block and Lt1 heads with BTR cam, dod delete that uses press in plugs and no o ring under the valley cover, it has new oil pump, katech front cover, chain, tensioner, etc Just wanting to see if anyone else is seeing low oil pressures, I'm seeing 20 psi at idle and normal psi on the street. I've talked to one other Zl1 person that said their oil pressure was about the same and another said theirs as around 35 which is what my old motor was. Just checking.
02-27-2020, 07:42 AM | #2 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Curious, is the 20psi when hot or both hot and cold? Seems low to me.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
02-27-2020, 07:53 AM | #3 |
Drives: 2017 ZL1 A10 Summit White Join Date: Apr 2018
That was what mine was hot before the oil pump let go. Another sign was when at WOT, the pressure would go to max on the Guage.
02-27-2020, 08:34 AM | #4 |
That was cold and hot. We may have gotten a bad pump, we had to wait over 2 weeks to get it as they were on back order because of the December Holidays. We are checking the pressure at the filter and at the valley cover today to see what the difference is between the two. GM has a max between the two places to check it on determining what might be failing. I'll post once we find out this morning.
02-27-2020, 09:02 AM | #5 |
I assume the pump was the latest revision? That totally sucks...all that work and have to do it over again.
02-27-2020, 10:23 AM | #6 |
Pump appears to be ok according to the scan tool Matt uses and yes its the latest and greatest. We are loosing pressure between the oil filter and the valley cover sensor. He told me this morning its about 30 psi difference according to his GM scan tool
02-27-2020, 10:26 AM | #7 |
Is the filter reading done before or after the filter? Wondering if just a bad/clogged filter?
02-27-2020, 11:01 AM | #8 |
Drives: 2018 ZL1 Hyper Blue A10 Join Date: Jan 2018
I see 33-35 at idle and 42-45 during normal driving on a stock motor.
02-27-2020, 11:20 AM | #9 |
that is pretty good...only 1 time have i seen mine go over 40.
02-27-2020, 11:35 AM | #10 |
Drives: 2018 ZL1 Join Date: Oct 2019
Mine is 28psi at idle (hot) and around 40psi cruising, depending on RPM. Cold oil should show more pressure at idle.
2018 ZL1 A10 - Rotofab Intake, LT5 TB, TSP Headers, ATI Balancer, 9.1 Lower Pulley, JMS BAP, Flex Fuel.
02-27-2020, 03:11 PM | #11 |
I just got mine back from Matt at the dealership, he helps me at my shop but could not get here so took it to him. It tested 60 psi at the filter and 22.6 psi at the sensor at the valley cover. When you unplug the sensor in the front of the Katech front cover and that will make it go to the high side of the oil pump and pressure goes up to 36 psi. He was able to do that with the scan tool. I'm pulling the blower off this weekend and check the plugs in the valley cover then put the Livernois plate with the o rings back on so we are assured its not loosing it thru the plugs. If that does not work I'll have to pull the front cover and pan to check the bearings. Been there and last time it didn't turn out so good. But the oil pump is good and hopefully the wire that goes down to the pump is not pinched. Fingers crossed. GM guidelines has it within 1 psi on the low side.
02-27-2020, 05:43 PM | #12 |
My LT4 runs about the same pressure as Grumpy1s ZL1! I have over 10,000 miles on mine now.
02-27-2020, 09:45 PM | #13 |
Thanks for all the responses. I'll have it off this weekend and hopefully back up and going by Monday so I'll let you know the outcome.
02-27-2020, 10:12 PM | #14 |
Sarcasm loading --------
is there any metal in the oil?
if the pump was not aligned properly the gerotor pump will rub. you will lose pressure and the oil will look like it has metal powder floating in it. could be the pressure release as well. https://gm-techlink.com/?p=12041
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
