02-11-2019, 03:57 PM | #1 |
Drives: 2018 ZL1 1LE Join Date: Apr 2018
If you have American Racing Headers, CHECK THIS!
So some of you may recall I have been dealing with a weird issue getting Stabilitrak and Fuel Pump A Voltage Low codes when making hard left turns on the track back in Nov. Since then the problem got progressively worse.
Well since then we found the issue (today actually) and we found that on the passenger side main fuse box harness (under the coolant tank) there is a harness that instead of being ran on TOP of the frame rail, it runs next to it between the frame and the manifold. With ARH headers, the way the primaries are routed, the 1 7/8" headers will make contact with this harness under load and with the chassis twist under large G loads. 2" headers will nearly touch is sitting still. What we ended up doing after we repaired the harness was reroute the harness on top of the rail (as GM should have) and the issue is resolved. I will be adding head protection wrap next. My builder said he hasnt seen this issue with Kooks or SW headers due to their slightly different tube bends. If you have ARH headers, this is worth a look. I never knew this was happening until I tracked the car or did hard canyon runs. The issue NEVER happened on the street. So you could have this issue and not even know it yet. |
02-11-2019, 04:02 PM | #2 |
Good post. Though I feel like the installer should thoroughly check for good clearance at all points so this probably "shouldn't" have happened...But sounds like this was a car-to-car issue that was a GM assembly error.
02-11-2019, 04:05 PM | #3 |
You are correct, this could have been spotted however the installer hadn't been doing too many ARH systems due to the cost but I was insistent that we use ARH. Fortunately due to this he was able to go back to the ARH systems hes installed lately and revise them. He did say there is some variance in the slack on the harness. What actually happened is there is too much slack which caused it to bow out towards the header.
Consider this a learned experience. |
02-11-2019, 05:49 PM | #4 |
I just installed the 2 inch ones on mine! I am gonna have to take a close look at this. I had mine ceramic coated so I wonder if that would make a difference???
02-11-2019, 06:03 PM | #5 |
Drives: 2017 ZL1 6MT Join Date: Feb 2018
First, thanks for the heads up.
I recently installed a set of ceramic coated catless 1-7/8" ARH headers. My wire harness is ran on top of the firewall not on the side. Your installer took a different route than I did in installing the headers. I didn't have to touch that wire harness. I just checked just to make sure though...all good.
2017 ZL1 Arctic Blue Metallic / 6MT / sunroof / NAV / PDR / RotoFab CAI + dry filter / Tony Mamo TB V1 / Skip Shift Eliminator / Hurst Short Throw Shifter / ZL1 floor mats / Dead Pedal cover (to match other pedals) / ARH Catless 1-7/8" headers + ARH X-pipe + AWE Touring Axle-Back / Diode Dynamic smoked side markers / American Authority tow hook
02-11-2019, 06:16 PM | #6 | |
What we found is an inconsistent routine of the harness between cars. Didn’t matter if it was an 18 or 19. I figured this would be a quick thing to check since some (like mine) was routed to the side instead of on top of the rail |
02-11-2019, 06:17 PM | #7 |
Also to be clear this harness is running from firewall to the front of the fuse box, not along the firewall. This is the factory location for the harness
04-18-2020, 04:06 PM | #8 |
Drives: 2017 1SS cruiser/ 1985 Z28 racecar Join Date: Nov 2018
04-18-2020, 04:10 PM | #9 |
2018 ZL1-NFG-A10
New Iron L8T 9.32 147MPH |
04-18-2020, 06:02 PM | #10 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
Interesting. I have 2 inch ARH headers which were installed by Vengeance Racing. Not an issue at all on my ZLE. I agree with the above post that the install can head off this potential issue in advance.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
04-18-2020, 11:27 PM | #11 |
Drives: 2023 ZL1 M6 Join Date: Sep 2018
I wrapped mine in heat tap and zip ties with the push pins on the end to secure the harness to the frame rail. Tons of room now.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp, Jet Hot Coated ARH 2 inch LT's, Stainless Works NPP, Too High PSI Billet Valve Covers, Mighty Mouse Wild CC Signature Forged 20x10.5/20x11.5, 295/30-315/30, BMR springs, BMR Cradle lockout, AAD Billet Control/Trailing arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
04-19-2020, 03:55 PM | #12 |
Drives: Grandad's C2 L89 Join Date: May 2017
2018 ZL1 1LE sw/PDR
